Go buy a tube of Hylomar and a small tube of silicone marked
adhesive silicone , not gasket maker silicone
Use the Hylomar on the heads, valley pan (both isdes) and the intake manifold around the intake ports VERY SPARINGLY, really thin, used the silicone in the corners (a small dab in each corner) between the block, heads and valley pan
I like and use the gaskets if I can, I seal them up with Gasket Cinch first and then use Gasket Cinch to hold them on the valley pan, if I'm not using Hylomar on them
