604 on the dyno #1497183
09/06/13 03:22 PM
09/06/13 03:22 PM
campbell river B.C
mopartoby Offline OP
campbell river B.C
My 604 is sitting on muscle motors dyno today. Mike emailed me this morning and the first pulls made 1035hp and 840 ft/lbs. He was waiting for some more fuel to arrive so he can start tuning. I asked for a video so hopefully when I get an update later I can post a video and some numbers
Re: 604 on the dyno [Re: mopartoby] #1497184
09/06/13 03:24 PM
09/06/13 03:24 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Good day to be you! What's it going in?
Re: 604 on the dyno [Re: SpareParts] #1497185
09/06/13 03:36 PM
09/06/13 03:36 PM
California
mickm Offline
mickm  Offline
California
details?
Re: 604 on the dyno [Re: mopartoby] #1497186
09/06/13 03:37 PM
09/06/13 03:37 PM
Trumbull,CT.
jim sciortino Online content
jim sciortino  Online Content
Trumbull,CT.
Details, details, details.....
Re: 604 on the dyno [Re: SpareParts] #1497187
09/06/13 03:39 PM
09/06/13 03:39 PM
campbell river B.C
campbell river B.C
I'd have to dig back through my emails for the exact specs but its a 4.5 bore world iron block. B1mc heads sheet metal tunnel ram, 4.75 stroke callies crank, comp custom ground cam in the 820 lidt area. And its goin in a 25.1e tube chassis 70 cuda.
Re: 604 on the dyno [Re: mopartoby] #1497188
09/06/13 05:21 PM
09/06/13 05:21 PM
campbell river B.C
campbell river B.C
Well results will have to wait till monday. Mike needs some q16 fuel.
Re: 604 on the dyno [Re: mopartoby] #1497189
09/06/13 05:32 PM
09/06/13 05:32 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Look forward to hearing your results.
Re: 604 on the dyno [Re: mopartoby] #1497190
09/07/13 12:09 AM
09/07/13 12:09 AM
Trumbull,CT.
Trumbull,CT.
Looking forward to seeing it finished.
Re: 604 on the dyno [Re: jim sciortino] #1497191
09/09/13 06:41 PM
09/09/13 06:41 PM
campbell river B.C
campbell river B.C
Well not the final results yet but mike pulled 1093hp and 844ft/lbs at 7550 rpm he was jetting up and going for that 1100hp! !!
Re: 604 on the dyno [Re: mopartoby] #1497192
09/09/13 06:54 PM
09/09/13 06:54 PM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
Re: 604 on the dyno [Re: Cheatham] #1497193
09/09/13 08:18 PM
09/09/13 08:18 PM
Lansing, MI
MuscleMike Offline
MuscleMike  Offline
Lansing, MI
1093 HP @ 7550, 874 TQ @6100. We tried more jet and it didn't like it. That and I ran out of Q 16 after the last jet change so 1093 will have to do.....
Re: 604 on the dyno [Re: MuscleMike] #1497194
09/09/13 08:36 PM
09/09/13 08:36 PM
campbell river B.C
campbell river B.C
I'm pretty happy with 1093hp out of a 572 mike.
Re: 604 on the dyno [Re: mopartoby] #1497195
09/09/13 09:00 PM
09/09/13 09:00 PM
Lansing, MI
MuscleMike Offline
MuscleMike  Offline
Lansing, MI
As Toby has stated I made an executive decision to switch this to a 572 from a 604. Toby wanted Steel rods(Oliver's)so I elected to use the shorter stroke. Adding a bunch of stroke takes away from the efficiency of the engine and with the heavier bob weight(steel rods)I figured the engine would be "happier" with the shorter stroke.
If you use the available formulas the Original B1 heads doesn't need or want a lot of cubic inches.
Heads are B1MC's 2.400/1.80, Comp Roller, Isky EZ roll lifters, Jesel Rockers/Belt drive, ATI dampner, wet sump and a Morosso vacuum pump making 12+". We used our standard wedge dyno headers: 2"x 32" w/3" collector so I'm sure there are a few HP with a bigger, shorter tube header. And YES, Q16 makes power! Especially on a combination like this that is somewhat airflow limited.
Re: 604 on the dyno [Re: MuscleMike] #1497196
09/09/13 09:48 PM
09/09/13 09:48 PM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
was this with 2 - 4500s or single 4500, whats the comp. ratio ?
Re: 604 on the dyno [Re: Cheatham] #1497197
09/09/13 10:35 PM
09/09/13 10:35 PM
campbell river B.C
campbell river B.C
2 4500's sheet metal intake. Mike may have to chime in on the compression. I think its 15:1 ish
Re: 604 on the dyno [Re: mopartoby] #1497198
09/10/13 12:33 PM
09/10/13 12:33 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
More detailed info would be cool.
Which comp cam? Tit. valves.....Springs...
Tom
Re: 604 on the dyno [Re: RT540] #1497199
09/10/13 02:16 PM
09/10/13 02:16 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
So, they are B1 originals, 2-4500's, sheet metal tunnel ram, I'm curious if it's a Hogan, and a fairly aggressive cam profile. What will the car weigh with driver?
Re: 604 on the dyno [Re: camastomcat] #1497200
09/10/13 02:56 PM
09/10/13 02:56 PM
campbell river B.C
campbell river B.C
Cam is a comp custom grind, mikes got all the details. I gave him a list of what I wanted and a hp expectation and he handled the rest. Yes its a hogans intake. And yes it uses ti valves. As far as the b1's I ordered b1mc castings from koffels and had them drop shipped to mike. Its either a misprint on mikes part or koffels messed up and sent him originals. I'm hoping mike will chime in with a few more details for everyone. Couldn't be any happier with the numbers he pulled
Re: 604 on the dyno [Re: mopartoby] #1497201
09/10/13 03:45 PM
09/10/13 03:45 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
The numbers are impressive. What will the car weigh with driver?
Re: 604 on the dyno [Re: camastomcat] #1497202
09/10/13 04:15 PM
09/10/13 04:15 PM
campbell river B.C
campbell river B.C
I'm hoping to be in the 25-2600 lb area with me in it. I'm using as much carbon fiber as possible. Glass doors and frond end. Carbon tubs door panels and tunnel. 2 speed glide, dana 60.
