What rust killer do you prefer? #1497032
09/06/13 11:18 AM
09/06/13 11:18 AM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
I know this comes from time to time, but there is always something new or new experiences to share.
So, looking for some coating to use on a truck cab. I have used POR-15 and KBS in the past with good results, although seems like a lot of prep work.
What works for you guys?
Re: What rust killer do you prefer? [Re: nd65] #1497033
09/06/13 11:42 AM
09/06/13 11:42 AM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
I buy this at home depot. It's cheap and work great! It's located where all the thinners and paint clean up stuff is.
Re: What rust killer do you prefer? [Re: mopowers] #1497034
09/06/13 02:32 PM
09/06/13 02:32 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
zero rust. 1/2 the price of por15 and it does the same thing.
Re: What rust killer do you prefer? [Re: nd65] #1497035
09/06/13 02:34 PM
09/06/13 02:34 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I media blast all the rust away in my life. Don't care for the chemical approach myself.
Re: What rust killer do you prefer? [Re: Challenger 1] #1497036
09/06/13 02:48 PM
09/06/13 02:48 PM
dogdays Offline
dogdays  Offline
Black Beauty copper slag.
R.
Re: What rust killer do you prefer? [Re: dogdays] #1497037
09/06/13 05:13 PM
09/06/13 05:13 PM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
I'll look into Zerorust.
Media blasting is out of the question. I am sure that is the best approach though.
Is the Home Depot stuff just an etcher?
Re: What rust killer do you prefer? [Re: nd65] #1497038
09/06/13 05:53 PM
09/06/13 05:53 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I would be looking into rust eliminators, not rust "killers" ( or covers/encapsulators like Zerorust, POR15 etc.). Covered up rust ALWAYS returns, its only a matter of when.
Re: What rust killer do you prefer? [Re: ScottSmith_Harms] #1497039
09/06/13 05:58 PM
09/06/13 05:58 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
I like Evaporust. It seems to Eat the rust away completely as opposed to sealing it up. As a bonus, it's not very bad on you skin if you get it on you. Supposedly you could drink it but I wouldn't try it.
Re: What rust killer do you prefer? [Re: nd65] #1497040
09/06/13 06:04 PM
09/06/13 06:04 PM
AL
jglen490 Offline
jglen490  Offline
AL
Can't quite read the label, but if it's phosphoric acid based, then it will convert iron oxide (red) to iron phosphate (black). Still requires some prep work to get rid of the loose rust first so that the surface ends up being solid, and still requires protection after (primer/filler/paint).
Re: What rust killer do you prefer? [Re: jglen490] #1497041
09/06/13 06:44 PM
09/06/13 06:44 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Check this out (watch the video) same type of product as Evaporust concerning safe non toxic rust (only) remover. www.safestrustremover.com
Re: What rust killer do you prefer? [Re: jglen490] #1497042
09/06/13 06:45 PM
09/06/13 06:45 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Rust Mort
I am truckless..
Re: What rust killer do you prefer? [Re: 340SHORTY] #1497043
09/06/13 07:07 PM
09/06/13 07:07 PM
BDW Online content
BDW  Online Content
Re: What rust killer do you prefer? [Re: cjskotni] #1497044
09/06/13 08:30 PM
09/06/13 08:30 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
Funny thing about phosphoric acid ,it is in potato's ... the old folks would always clean their iron skillets and then rub them with a fresh cut potato to keep them from rusting! they even stuck the iron knifes in one also. I don't know about this product but,OSPHO has a "DICROMATE " to inhibit rust which is the second benefit after the conversion of existing iron oxide. you definitely would not want to drink it [OSPHO]..
Re: What rust killer do you prefer? [Re: nd65] #1497045
09/06/13 08:53 PM
09/06/13 08:53 PM
E
ek3 Offline
ek3  Offline
E
this is one of the absolute best products you will ever see. it is a heavy weight knock out champ of champions ! http://products.bowersindustrial.com/ite...ating/item-1009
Re: What rust killer do you prefer? [Re: BDW] #1497046
09/06/13 09:03 PM
09/06/13 09:03 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
Re: What rust killer do you prefer? [Re: bonefish] #1497047
09/06/13 09:20 PM
09/06/13 09:20 PM
IN
ahy Offline
ahy  Offline
IN
I have had great results with Eastwood rust encapsulator and good old red Rustoleum. Clean very well to get any/all grease off. Wire wheel or scrape to get any loose rust or paint off and prime. Rust encapsulator can take an automotive top coat with fairly short dry time (overnight). Red Rustoleum needs lots of cure time if you want to put automotive paint over it as the solvents can lift it.
Re: What rust killer do you prefer? [Re: ScottSmith_Harms] #1497048
09/07/13 05:03 AM
09/07/13 05:03 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Scott...have you used this product yourself? I'm intriqued by it!
Re: What rust killer do you prefer? [Re: Quicksilver440] #1497049
09/07/13 11:57 AM
09/07/13 11:57 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes and I was so impressed with it I am now a dealer for them (and just in case anyone is wondering, I only sell it locally so my post is not some sort of thinly veiled sales pitch). It does everything it says it will on the website.
I compared it directly with Evaporust (which is also a very good product). Basically it does the same thing but with a few advantages. It costs a little less than ER for two reasons, #1, it is roughly $85.00 for 5 gallons (shipping can vary that a bit) which is less than ER usually costs around here, and #2, I've found that it will last longer/processes more rusty parts before it stops working.
While both products attack only the rust causing no damage to good metal, plastic, paint markings, etc. SRR is a thinner product, nearly the consistency of water while ER is thicker, something similar to antifreeze. Because of this you can use a recirculation pump to pump the SRR over the parts (for larger parts or areas this is critical because you need to submerge parts entirely if using ER) you can pump ER over parts as well but it's thicker viscosity can overwork and burn up pump motors.
It leaves a nice clean surface on bare metal. Once I remove parts from it I don't even rinse them off, I just wipe them with a clean rag and let them dry, this keeps the parts protected from flash rust for a few days (or longer). Once I am ready to treat the parts with paint or rust protectant like ECS's RPM, I simply wipe them down with wax and grease remover and treat them as normal.
*FWIW I've used EVERY rust removal product mentioned on this thread and can honestly say that while each is a good product for it's intended use, nothing with the exception of ER comes close to SRR when it comes to the job of efficiently removing rust from parts in a safe manor (that won't etch, dissolve, or damage, good metal or other parts).
Re: What rust killer do you prefer? [Re: ek3] #1497050
09/07/13 01:44 PM
09/07/13 01:44 PM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
Lots of different stuff out there. The Bowers stuff looks interesting.
I am not looking to remove rust, but coat over it.
Thanks guys
Re: What rust killer do you prefer? [Re: nd65] #1497051
09/07/13 10:08 PM
09/07/13 10:08 PM
OHIO
THE GLASS MAN Offline
OHIO
I am sure that most of these products work fine for their own recommended use, but what would be the perfect product for metal a barn roof.
