What overdrive trans fits a 440 ? #1496991
09/06/13 10:43 AM
09/06/13 10:43 AM
Connnecticut
acesneights Offline OP
Connnecticut
Would like OD behind my 440 in my RV.
What would work ?
1975 Dodge Travco 440 BB 1972 Dodge Travco 318 SB
Re: What overdrive trans fits a 440 ? [Re: acesneights] #1496992
09/06/13 10:48 AM
09/06/13 10:48 AM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
I am assuming you are looking for an automatic OD for an RV and the short answer to that question is there is no OD that will bolt on to any BB Mopar.
The easiest thing I could think of for you to investigate would be to go the Gear Vendor OD route. Pricey unit but would probably require few mods to your RV...probably just a shortened driveshaft would be the worst. This is a unit that bolts on to your existing 727 (replaces tail shaft) and adds the overdrive. They seem to run in the ~3K range IIRC.
Re: What overdrive trans fits a 440 ? [Re: acesneights] #1496993
09/06/13 12:06 PM
09/06/13 12:06 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Skip the Gear Vendors and get a 518.
I'm putting one behind the 440 in my Imperial. Ultrabell has a bellhousing that joins the two. It requires cutting the bellhousing back to the front pump and bolting the new one up.
The transmissions are tough and not much longer than a regular 727. The OD ratio is .69 which is a bit better than the .79 of the GV unit. It's a few thousand dollars cheaper too.
Some people talk about the ability to split gears with a GV but I haven't found anybody who really uses it that way. It's a bit cumbersome to shift it like that.
- Stu Harmon
Re: What overdrive trans fits a 440 ? [Re: feets] #1496994
09/06/13 12:54 PM
09/06/13 12:54 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
That may be a possibility as well but more to it than the GV unit. Also would a motorhome have the shorty 727? Not sure if there would be more fitment involved or not. Plus you will need a fabricated tranny cross member Also you have to have a vacuum modulator for the OD/lockup but yes this can be done as well.
I was trying to suggest an easy route. Unless you can fabricate yourself on the cheap, I can see this route getting as expensive as GV unit. That and all the hassle of having to source the transmission, build to handle the 440, cut/replace the bell, fabricate the cross member, install/tune the OD/lockup vacuum control, and then new driveshaft....that's if it can fit in the RV without floor pan mods.
This is a valid route but I wouldn't agree that it's guaranteed cheaper that the GV. I would just think with an RV, you would want 'easy' as opposed to lots of custom fabrication work.
Re: What overdrive trans fits a 440 ? [Re: cjskotni] #1496995
09/06/13 12:56 PM
09/06/13 12:56 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Fitting the OD in a van body should not be much of a hassle.
I don't see why so many people are afraid of this swap. I don't see any challenges to it and I'll have under $1000 in the whole thing when it's done. That price includes the Ultra Bell, transmission, and rebuild.
- Stu Harmon
Re: What overdrive trans fits a 440 ? [Re: acesneights] #1496996
09/06/13 01:23 PM
09/06/13 01:23 PM
What would work ?
What class RV, A,B or C? If it is a full chassis class A with big tall 19.5 or 20 inch tires I put a Eaton two speed rear end in my old class A, took out a 4.89 ratio stock and put in a 4.56 in direct and 6.17 in underdrive, that worked real well
Re: What overdrive trans fits a 440 ? [Re: acesneights] #1496997
09/06/13 01:32 PM
09/06/13 01:32 PM
minnesota
P
president61 Offline
president61  Offline
P
minnesota
my neighbor put a 518 in his motorhome and he loves it. it is behind a 360 though, which of course is easier
Re: What overdrive trans fits a 440 ? [Re: president61] #1496998
09/06/13 02:05 PM
09/06/13 02:05 PM
dogdays Offline
dogdays  Offline
The answer is split 50/50.
It all depends.
The GearVendors has been used for several years in motorhomes and it may well be possible to buy an existing setup. I've seen the overdrive units at swap meets in the $1000 range, the company will sell you the rest of the parts to make it work. If you're savvy enough to get ths far, getting the driveshaft modified is a piece of cake. Many longer wheelbase vehicles have two-piece driveshafts and those are very easy to shorten.
The Mopar overdrive automatic transmission is also an atractive option, cut off the bellhousing and swap on an aftermarket one. There are issues with the sttarter, but can be solved, thousands have.
Building the 518 to handle 440 power is no problem either, as the front if it is a 727.
BUT, the later auto trannys have been strengthened for use in front of Cummins and V10 engines, and I'd think of looking at those. Electronic controls sound daunting but I believe are easier to get right in the long run. Having a lockup converter would be nice, as well.
In conclusion, both ideas are attractive and both if done properly will cost about the same. I'd start looking at swap meets or CL and start talking to your favorite modern Mopar auto tranny shops to see which way the dice will land for you.
Also, Feets, thanks for keeping your eye on the ball about cost. That's important. I hope your transmission lasts a long time.
R.
Re: What overdrive trans fits a 440 ? [Re: feets] #1496999
09/06/13 02:07 PM
09/06/13 02:07 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
If I ever have some spare change this is the route I will go as I would want the steeper overdrive than the GV unit. However, if you can do all this for $1000, you have a hookup somewhere and/or you are doing the work yourself which is beyond what little skill I have.
Hell, I'll give you $1000 right now if you can give me a A518 built and ready to bolt on to a my 400 stroker in my 73 Charger! I can't even find a rebuilt A518 from the correct year for under $1000 after shipping...and even with a junker, the rebuild kits are pricey and then the labor to have them done. I wish I had the skill to build this myself. :-(
At least now we have two options for the OP.
Re: What overdrive trans fits a 440 ? [Re: cjskotni] #1497000
09/06/13 02:10 PM
09/06/13 02:10 PM
dogdays Offline
dogdays  Offline
Who said anything about "built"?
Start out with a good junkyard A518 and do the swap. Remember, the car was moving when it ran into the immovable object!
R.
Re: What overdrive trans fits a 440 ? [Re: cjskotni] #1497001
09/06/13 02:11 PM
09/06/13 02:11 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I'm no great shakes with a welder and I got it done on my Duster. As a former RV tech I can assure you there is far more room under an RV for a trans than my Duster.
Re: What overdrive trans fits a 440 ? [Re: cjskotni] #1497002
09/06/13 02:48 PM
09/06/13 02:48 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If I had the extra time I'd drag another one out of the Pick N Pull.
Do you have a dial caliper, a set of snap ring pliers, and access to a shop press?
If so, you'll have everything you need to build a transmission.
Follow the steps in the factory shop manual and pay attention. It's easier than you'd think.
- Stu Harmon
Re: What overdrive trans fits a 440 ? [Re: feets] #1497003
09/07/13 12:19 AM
09/07/13 12:19 AM
Chester, VA
tobnHisglory Offline
Chester, VA
Now you've got me curious about the A518 swap. What is involved in cutting off the old bell housing for the ultra bell conversion? Where do you cut? Where do you drill? Is there a diagram for this anywhere?
-Reggie
tobnHisglory2000@aol.com
Former Mopars: 73 Charger - 440/727, 68 D200 Camper Special 383/727, 67 Satellite, 71 Superbee, 73 RoadRunner,2009 Ram Quad Cab Hemi 4x4
Current Mopars: 2005 Ram Quad Cab Hemi 4x4, 73 Cuda FE5 318 manual
Re: What overdrive trans fits a 440 ? [Re: tobnHisglory] #1497004
09/07/13 12:26 AM
09/07/13 12:26 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I believe the replacement bell housing is held in by the bolts that hold in the front pump. The 'Ultra-Bell" kit comes with longer bolts to account for the thickness of the flange.
Re: What overdrive trans fits a 440 ? [Re: Kern Dog] #1497005
09/07/13 03:13 AM
09/07/13 03:13 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
There is another way.PTC trans has a kit that uses an 95 or older A-518.The 361-440 block will have to have the drv side lower bolt area cut off the block to clear room for the starter.No ultra bell only an adapter.They also have a very slick way to run the overdrive and the lockup.No on-off switch to reset at every stoplight.
Leave the gun.......take the Cannoli's....Mike
Re: What overdrive trans fits a 440 ? [Re: mike s] #1497006
09/07/13 10:43 AM
09/07/13 10:43 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I think I'd like to avoid cutting an ear off the block.
- Stu Harmon
Re: What overdrive trans fits a 440 ? [Re: acesneights] #1497007
09/07/13 01:50 PM
09/07/13 01:50 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
A pic of the 518 with an Ultrabell housing installed.
Re: What overdrive trans fits a 440 ? [Re: feets] #1497008
09/08/13 05:55 AM
09/08/13 05:55 AM
Turbo383 Offline
Turbo383  Offline
Feets - this is off the subject - but have yo had any problems
with the turbo bearings? Do you use a pre-oiler or hydraulic accumulatorS?
Thanks!
Re: What overdrive trans fits a 440 ? [Re: Turbo383] #1497009
09/08/13 11:47 AM
09/08/13 11:47 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I've had one turbo coke the bearings but I think it was due to a poor drain line angle. Engine torque smacked the line on the frame rail and angled it upwards. Oil was slow to drain and cooked in the bearing housing.
- Stu Harmon
Re: What overdrive trans fits a 440 ? [Re: John_Kunkel] #1497010
09/08/13 12:01 PM
09/08/13 12:01 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
A customer in Denver fit this setup into his 74 Charger. Turned out really sweet.
Tranny shop in Denver sells the rebuilt BB 518 for around 1200.00 IIRC. Ready to bolt in.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
