Max Wedge Piston ID Help 2406648 #1496680
09/05/13 03:21 PM
09/05/13 03:21 PM
Denver, CO
Oneida Garage Offline OP
Denver, CO
I have a couple sets of pistons here, all stamped 2406648. I'm pretty sure they are 413 Max Wedge pistons but I have consulted all my parts books and I cannot find a match - not in factory parts books, Davis books, Schild guide, etc.
They have a .063" dome height and measure about 4.200" OD on my calipers, I don't have a micrometer big enough.
Can anyone out there help me out with an ID? Many thanks.
Re: Max Wedge Piston ID Help 2406648 [Re: Oneida Garage] #1496681
09/05/13 04:13 PM
09/05/13 04:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
They look like 11-1 MW pistons, 4.20" would be .020" over 413....too small for a 426.
Re: Max Wedge Piston ID Help 2406648 [Re: John_Kunkel] #1496682
09/05/13 04:15 PM
09/05/13 04:15 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Part number looks like a old Direct Connection # maybe?
Brian
Re: Max Wedge Piston ID Help 2406648 [Re: '72CudaRacer] #1496683
09/05/13 04:39 PM
09/05/13 04:39 PM
Denver, CO
Denver, CO
another picture.
I measured again, and while the OD is ~4.200" at the top of the piston, it measures ~4.245" across the bottom of the skirts. I checked a few, they are all similarly tapered.. I didn't realize they had that much taper.
If anyone could find a listing for a 2406648 anywhere, I'd be very grateful. At this point I am thinking it's an 11:1 426 piston.
Re: Max Wedge Piston ID Help 2406648 [Re: Oneida Garage] #1496684
09/05/13 06:01 PM
09/05/13 06:01 PM
dogdays Offline
dogdays  Offline
Re: Max Wedge Piston ID Help 2406648 [Re: dogdays] #1496685
09/05/13 06:30 PM
09/05/13 06:30 PM
Denver, CO
Denver, CO
Thank you for the links, I did see those reference to the piston when I did an internet search. But I cannot find the numbers in a book, manual, or from a reputable source, such as I'm hoping to find here. Thanks again everyone.
Re: Max Wedge Piston ID Help 2406648 [Re: Oneida Garage] #1496686
09/05/13 07:11 PM
09/05/13 07:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Standard bore 426 piston, dome is 11-1.
Re: Max Wedge Piston ID Help 2406648 [Re: Oneida Garage] #1496687
09/06/13 02:44 AM
09/06/13 02:44 AM
Stock bore 1963 M.W. 415 HP Hows the top ring land side clearances to the rings
Re: Max Wedge Piston ID Help 2406648 [Re: Cab_Burge] #1496688
09/06/13 11:23 AM
09/06/13 11:23 AM
Denver, CO
Denver, CO
Thanks you guys.
I'll check the ring clearances - Don't have a feeler gauge here.
Have one set to keep and use, one set to sell.
Thanks again and best wishes!
