Aluminum rocker arm failure - replace one or all?
#1496638
09/05/13 02:41 PM
09/05/13 02:41 PM
Posts: 561 Oakland, CA
68Bullet
Oakland, CA
I experienced a failure on one aluminum rocker arm on Monday. See attached picture. The rocker arm split in half right where the adjusting screw is. The engine is a 383 big block, with a .550 lift mechanical roller cam and matching double springs on ported cast iron heads. My set of roller rockers is from Hughes Engines, but this post is not meant to knock them. It is merely to get some feedback on what I should do. The failure occurred right off of idle, as I was SLOWLY accelerating from a stop sign. Out of nowhere a loud ticking noise developed, and I knew it was wrench time.
So if one rocker arm failed, should I be concerned that the others might fail? The engine has about 5,000 miles on it. All of the other rockers look OK (no signs of stress cracking or fatigue). Should a person not run aluminum rocker arms with a roller cam? Or is this an isolated incident? Should I check the head for something weird (stuck valve or something?). In an ideal world I would replace the one rocker and get back on the road, but more importantly, I want to do what it takes to not have future failures.
Re: Aluminum rocker arm failure - replace one or all?
[Re: dogdays]
#1496640
09/05/13 04:09 PM
09/05/13 04:09 PM
Posts: 2,042 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
I broke a Mopar alum roller rocker (same as a Crane gold). Took a while to understand why, but it turned out that the ground electrode came off of the spark plug and momentarily created a solid "hit" on that valve rocker. Replaced that one rocker and still run them now, 2 years later with no problems. In your case though, seeing where its damaged, I'm wondering if its possible that the jamb nut was over tightened, causing the inital weakening. Just an idea, but I do agree, you gotta find the root cause of the failure. Brian
[Re: 68Bullet]
#1496642
09/05/13 05:07 PM
09/05/13 05:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Check your P to V clearance... but if thats plenty then I would pull the spring and see if the valve is bent or the spring ins broke... if thats fine then I would see what the rockers can take for max open pressure.. if it is all fine then I would just replace the rocker and move on.... I've only seen a break of that nature when something bottomed out... even a over tightened lock nut shouldnt do that... that would tend to rip the threads out... JMO
[Re: 68Bullet]
#1496644
09/06/13 01:17 AM
09/06/13 01:17 AM
Posts: 4,206 New York
polyspheric
New York
How much adjuster thread was exposed?
Boffin Emeritus
