Steering problem #1496629
09/05/13 02:14 PM
09/05/13 02:14 PM
Western NY
19SuperBee70 Offline OP
Western NY
I have a steering problem on a non mopar. Recently bought an 88 GMC suburban 4 wheel drive, solid axle in the front. I'm having a problem where occasionally the truck will want to turn to the right or the the left. You can fell the steering wheel wanting to pull the truck, You can hold the wheel and continue to drive straight but if you let go the truck will turn. This lasts a few seconds then stops, may happen several times in a row in either direction. Doesn't feel like something is loose or broken, feels like something is trying to turn the wheel. May last for a minute then the truck drives fine. Did it this morning pulling out of the house then again 45 minutes later pulling into work. First thought it was the steering box so replaced with reman cardon. Steering is basically tight except for this, wanders here and there but much better with the box. Everything looks good underneath, replaced drag link and rag joint at same time as box.
Is there any way the pump could cause this? I ask because when it happens it feeld like the assist is causing the wheel to turn, hard to explain. But I would think a bad pump would either over assist or underassist, not steer one direction or the other.
I also did drivers balljoints recently, didn't align afterwards. Can only toe be set on 4wd without alot of effort, Would toe cause this or just a wandering?
Other thought is cracked frame with Chevy is famous for. I checked when the box is out and looked good.
The rest of the suspension componenets are solid...no play or slop, bushings are good, no obvious broken or loose parts. Any thoughts? Next step is check the toe then have someone turn the wheel while i check to see if the box flexes.
Re: Steering problem [Re: 19SuperBee70] #1496630
09/05/13 02:59 PM
09/05/13 02:59 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
How are the ballots and Tie rod ends?
Re: Steering problem [Re: 76dodgeboy] #1496631
09/05/13 05:38 PM
09/05/13 05:38 PM
Western NY
Western NY
Ball joints on the driver side are new, US made. Passenger side appears good, at least when you try to wobble the wheel. Tie rod ends look ok, there is no slop in any of the parts when you try to move them.
I did the ball joints on the drivers side, they use a threaded insert to set the preload on the upper balljoint. No real adjustment there unless you could get an offset insert
Re: Steering problem [Re: 19SuperBee70] #1496632
09/05/13 05:51 PM
09/05/13 05:51 PM
San Francisco
dilvoy Offline
dilvoy  Offline
San Francisco
I'm assuming that you have power steering. Try changing the power steering fluid a couple of times. Maybe it's dirty and the valve in the power steering box is getting stuck. One of those oil sucker things is great for sucking the fluid out of the pump reservoir.
Re: Steering problem [Re: dilvoy] #1496633
09/05/13 06:15 PM
09/05/13 06:15 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Did you miss where he changed the steering box. Important sure most if not all the fluid is new
Re: Steering problem [Re: 19SuperBee70] #1496634
09/05/13 07:13 PM
09/05/13 07:13 PM
N
NITROUSN Offline
NITROUSN  Offline
N
axle joints.
Re: Steering problem [Re: 19SuperBee70] #1496635
09/05/13 08:48 PM
09/05/13 08:48 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
It could still have those obnoxious auto hubs that are trying to lock on you going down the road, but that usually is accompanied by some noise IIRC.
Re: Steering problem [Re: buildanother] #1496636
09/05/13 09:17 PM
09/05/13 09:17 PM
Western NY
Western NY
Fluid is new and flushed the pump but I'll check again tomorrow. Could low or high fluid pressure cause issues? or would it just increase or decrease the amount of assist.
I'll check the pass side ujoint tomorrow. Just remembered I changed the drivers side when I did the ball joints and it looked to be original to the truck, it was in pretty bad shape. Going to pull the pass wheel again anyhow to check the ball joints one more time.
No auto hubs luckily, manual warns (I think) on the front.
Could a rear posi cause these issues? It has a gov-lock and I've been reading they aren't the most reliable. Maybe clutches are sticking?
Re: Steering problem [Re: 19SuperBee70] #1496637
10/06/13 12:46 AM
10/06/13 12:46 AM
Western NY
Western NY
NITROUSN nailed it. Finally got around to checking the u joints and the pass side was seized in one plane. Replaced and drives like a charm!!!
