727 transmission servicing question #1496398
09/04/13 11:14 PM
09/04/13 11:14 PM
Badge Offline OP
Badge  Offline OP
I am about to drop the pan on a mid 70's 727 transmission to change the filter. It has the stock pan. Can someone give me a approximation of how many quarts of trans fluid I should buy? Thanks
Re: 727 transmission servicing question [Re: Badge] #1496399
09/04/13 11:22 PM
09/04/13 11:22 PM
Andrews,In. U.S.of A.
67_Satellite Offline
My fuzzy memory says 6. Don't dump them all in at once though,don't want to overfill.Put in 4 ,start up and check fluid level, add as needed.
Re: 727 transmission servicing question [Re: 67_Satellite] #1496400
09/04/13 11:40 PM
09/04/13 11:40 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
I'll agree with the 6 qts to buy
But there are several variables involved with this question.
I'd start with 2 or 3, Cycle through all the gear positions and add as needed. If cold, leave it 1/2 quart or 1 pint low until at operating temp as ATF expands when warm
