Is this an original engine compartment tag? #1496387
09/04/13 10:07 PM
09/04/13 10:07 PM
New Brunswick Canada
copperSwinger Offline OP
71 swinger windsor build. someone sprayed the engine compartment with undercoating early in its life, and underneath, I found this while cleaning it. Is this original? it appears to be a thick perforated paper that looks faded pink and was taped on.
it has smaller numbers below the letter
Re: Is this an original engine compartment tag? [Re: copperSwinger] #1496388
09/05/13 08:40 AM
09/05/13 08:40 AM
SE PA
MattMPA Offline
MattMPA  Offline
SE PA
My '72 Scamp didn't have one...but I have seen that tag on at least one Windsor A body.
Re: Is this an original engine compartment tag? [Re: MattMPA] #1496389
09/05/13 09:28 AM
09/05/13 09:28 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
Think it belongs on a Barracuda.........
Troy
Houston Mopar Connection Club
Re: Is this an original engine compartment tag? [Re: hemi68charger] #1496390
09/05/13 04:19 PM
09/05/13 04:19 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
Cool!! I was hoping to see another one of those tags someday. Here's a couple pics of one I found on the front pass. side floor pan under the carpet on my old 71 Charger R/T 440 4 spd. Car was assembled at Lynch Road. The little tag also has an inspectors punch on it if you look close.
Re: Is this an original engine compartment tag? [Re: EL5 71] #1496391
09/05/13 04:21 PM
09/05/13 04:21 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
Back
Re: Is this an original engine compartment tag? [Re: EL5 71] #1496392
09/05/13 10:19 PM
09/05/13 10:19 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
used to throw them away by the hundreds when I worked as a detailer at a company where the new cars came in off the railcars.. along with tons of buil sheets.
I am truckless..
