69 Coronet Charging System Blues #1496360
09/04/13 09:34 PM
09/04/13 09:34 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Took my new Coronet out for the first cruise and it didn't go so well. When I got it, the battery was dead, so I charged it up and everything looked fine. When I drove it, the ammeter needle stayed slightly below the middle, and dropped when I braked or signaled. Typical for an old car. Yet when it sits for a day or two the battery drains again. I got it jumped for the trip home, but it is definitely running off the battery and not the alternator.
Any ideas as to why it would drain when it is not being used? Someone told me the ammeter connections could be loose and that is draining it. I think it's a bit more complicated since the system won't recharge the battery when it's running.
Someone already replaced the ballast resistor with another incorrect one that gets very hot. I'm thinking I need to replace it again and maybe the voltage regulator.
What tests can I do to isolate the problem before I go spending lots of $$?
Thanks!
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: 69 Coronet Charging System Blues [Re: Erik] #1496361
09/04/13 11:12 PM
09/04/13 11:12 PM
oklahoma
69suprbee Offline
69suprbee  Offline
oklahoma
Sounds familiar.my 69 bee went thru some similar problems.1 st thing would be to see what voltage you get at battery with car running.should be somewhere in the 13.5 to 14.5 area,if its in the 12 area you're not charging.voltage reg is a suspect.these old cars suffer from voltage drops sometimes from bulkhead connections.be sure connections are clean and tight at bulkhead and then put some dielectric grease on them.could of course be an alternator problem if its not charging.time to get the volt meter out.good luck.btw you might look up the mad electric ammeter bypass.best thing I have done to my bee.
Re: 69 Coronet Charging System Blues [Re: Erik] #1496362
09/05/13 02:56 AM
09/05/13 02:56 AM
All 1969 brand Mopars are famous for wiring problems, as already suggested to you check the back nuts on the ammeter first before replacing any other parts, second thing is to check both sides of the bulkhead connectors for both amp wires, in and out and then check the battery voltage with the key off anf agian with the motor running revved up beyond 1200 RPM, if it isn't reading more than 12.75 volts revved up find out why Make sure the alternator belt is tight, real tight
Re: 69 Coronet Charging System Blues [Re: Cab_Burge] #1496363
09/05/13 10:55 AM
09/05/13 10:55 AM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Thanks for the replies. I have spare ballast resistors and voltage regulators, so I know what I'll be doing this weekend!
Re: 69 Coronet Charging System Blues [Re: Erik] #1496364
09/05/13 11:40 AM
09/05/13 11:40 AM
Andrewh Online content
Andrewh  Online Content
can't see how the balast or vr would cause a sitting drain.
if you aren't charging at all, then I agree, the vr needs to be looked at.
but back up and run a few tests first.
as said above, find out what voltage you see when it is running, and reved up to say 2k, at the battery.
if it is as simple as that, then good.
but if you are charging, you might start taking a look at what possible drains you have going.
a light on you don't see or power bleeding through some switch, or something wired incorrectly.
I know many people leave their older stocker type cars sitting for months without having to charge up the battery to run.
Re: 69 Coronet Charging System Blues [Re: Andrewh] #1496365
09/05/13 12:22 PM
09/05/13 12:22 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Ballast resistor has nothing to do with charging and they are supposed to be hot. Resistance causes heat.
Re: 69 Coronet Charging System Blues [Re: Andrewh] #1496366
09/05/13 01:05 PM
09/05/13 01:05 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
I have a few ideas as to what the drain is as the car has a lot of aftermarket gauges, radio etc that I know are not wired correctly. I will also check the ammeter nuts as suggested.
It is not charging at all, so I'm confident the VR needs to be checked and possibly replaced. I will also check the alternator to make sure it's not the problem as well. I have extras of all of this stuff so I will be able to identify the problem without going and spending lots of time and $$.
It has an incorrect ballast wired in bypassing the correct one which is still on the firewall.
Re: 69 Coronet Charging System Blues [Re: Erik] #1496367
09/05/13 02:15 PM
09/05/13 02:15 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I know this sounds crazy, but do you still have points init?
Re: 69 Coronet Charging System Blues [Re: Erik] #1496368
09/05/13 03:21 PM
09/05/13 03:21 PM
Is your alternator a single field or dual field unit? If dual field make sure both feild wires have voltage on them with the key on and the motor not running If not fix that first now the other thing to do is to check the output voltage from the alternator with teh engien running at the back of the alternator on the big wire Let us know what you find No magic in this stuff, just problems
Re: 69 Coronet Charging System Blues [Re: Cab_Burge] #1496369
09/05/13 03:45 PM
09/05/13 03:45 PM
2 potential problems (1) what Cab said see what your charging voltage is at the batt (2) With everything off at midnight take off a batt cable from either the neg or the positive batt post & if you see a spark there is something on that shouldn't be on that is draining the system. I think it's related to #1 but do check.
Re: 69 Coronet Charging System Blues [Re: 71birdJ68] #1496370
09/05/13 04:36 PM
09/05/13 04:36 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Yes, still has points
Re: 69 Coronet Charging System Blues [Re: Erik] #1496371
09/05/13 08:21 PM
09/05/13 08:21 PM
Groveland, MA
SteveS Offline
SteveS  Offline
Groveland, MA
A bad diode in the alternator can cause current drain when off, and interfere with charging.
Steve
Someday I'll have another C-body.
Re: 69 Coronet Charging System Blues [Re: SteveS] #1496372
09/07/13 02:49 PM
09/07/13 02:49 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Alternator was shot. Hopefully that was it!
Re: 69 Coronet Charging System Blues [Re: RapidRobert] #1496373
09/08/13 12:08 AM
09/08/13 12:08 AM
Omaha Nebraska
Brian_wo Offline
Brian_wo  Offline
Omaha Nebraska
or in the middle of the day pull the same cable off and put a test light between the cable and the battery and if it lights up there is a draw.
who is that guy?
Re: 69 Coronet Charging System Blues [Re: Erik] #1496374
09/08/13 01:00 AM
09/08/13 01:00 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Ok, hope that fixes it. The thing with the points, my 318 69 when the points would start going bad, the amp better would act crazy, way over charging and other stuff. Then if I put new points in it was ok.
Re: 69 Coronet Charging System Blues [Re: 71birdJ68] #1496375
09/08/13 01:11 AM
09/08/13 01:11 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: 69 Coronet Charging System Blues [Re: Alaskan_TA] #1496376
09/10/13 09:28 AM
09/10/13 09:28 AM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
New alternator and the charging system is back to normal. Now to figure out why the reverse lights keep blowing the fuse!
