Re: Alternate way of doing Airconditioning.
[Re: moposcar]
#149587
11/12/08 01:18 PM
11/12/08 01:18 PM
Posts: 169 arizona
VPrace
arizona
I was trying to think of a way to put A/C in my 56 w/out having somthing sticking below the dash (with only a couple of vents) like the ones from vintage air, etc, and I came up with an idea. I don't know if it has been done before, but could you mount an heater/A/C box from another car behind the rear seat and bring vents in from that direction? I know you wouldn't want to turn the vents 90 deg, but then would it matter? The suburbans have vents going down the length of the vehicles. You could even have rear defrost!!
Has anyone tried this, is it even possible, or is there something I am missing? I know the vans in the old days had the rear A/C and heat units and they just ran more hoses back there. Same with semi trucks.
doesn't vintage air make a rear mount box?
[Re: moposcar]
#149588
11/14/08 02:42 PM
11/14/08 02:42 PM
Posts: 425 Eastern Ontario
shaker340
Eastern Ontario
Go to the wreckers and get a rear AC unit out of any Minivan, large SUV or any vehicle that has one. I designed the rear unit for the Ford Freestyle, at the time (2003) it was the smallest rear unit to push 200 cfm. Watch for where the condensate drain is, and how it is oriented as it must point downwards. Some of the newer ones are smaller now.
You can run vents anywhere, but will lose cfm for long runs and if any bends in the run.
2008 Challenger SRT8 1940 Chrysler Royal coupe
[Re: John_Kunkel]
#149590
11/14/08 04:36 PM
11/14/08 04:36 PM
shaker340
Eastern Ontario
John, what is that out of? It looks like older style of AC case. But yes, that the idea for sure.
[Re: shaker340]
#149591
11/14/08 07:56 PM
11/14/08 07:56 PM
Posts: 25,933 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The unit in my trunk is a Vintage Air Super Cooler, VA makes a unit for trunk mount but the installer opted for the under dash type instead.
