Re: BB 11" manual drum brakes
[Re: MOPAULY]
#1495292
09/02/13 08:23 PM
09/02/13 08:23 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Bleed your system again. Manual brake systems dont have proportioning valve, they have distrubition blocks..
I am truckless..
[Re: Cab_Burge]
#1495294
09/03/13 11:33 AM
09/03/13 11:33 AM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
Cab thats backwards from all bleed sequinces Ive ever read.You always start RR then LR then the fronts.Only one differnt Ive done in over 40 years was the split diag systems.Then it was RR LF LR then RF.Rocky
Chrysler Firepower
[Re: Cab_Burge]
#1495297
09/03/13 02:22 PM
09/03/13 02:22 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Properly set up(adjusted and bled) should have a rock hard pedal 1/4 to 1/3 of peddle travel from top
I'd agree with that...
Describes mine...
DOT 5 fluid...Shoes adjusted...
I bleed from the furthest point back...
[Re: RSNOMO]
#1495298
09/03/13 03:43 PM
09/03/13 03:43 PM
Posts: 5,166 CT
GTX MATT
CT
The sequence Cab recommended sounds backwards to me as well, but I recently heard/read somewhere else to do it that way. I always start furthest from the MC and work my way closer and I've never had a problem.
Pedal should be rock hard only slightly depressed, as described. You will never get these things anywhere near the floor once all setup correctly and bled.
[Re: MOPAULY]
#1495306
09/10/13 10:56 PM
09/10/13 10:56 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Car was off the road since 83. I think it may be the front rubber lines,
Don't even mess with 'em...
Replace 'em...
[Re: RSNOMO]
#1495307
09/12/13 01:45 PM
09/12/13 01:45 PM
Posts: 7,843 Spring Mount, PA
MOPAULY
Spring Mount, PA
I'm stumped. All new hard lines, soft lines, wheel cylinders, and on a second master cylinder from Summit. I pulled a rubber line on the front and was able to draw a solid line of fluid from the hard line; I then placed the rubber line in a container and was able to pull solid fluid through it. I put it back together and I can only get a trickle from the front bleeder screws. I can't imagine I need a thread sealer on the bleeder screws! Is it possible there is an issue with the junction block not working correctly? After all of this I still have to pump the brakes multiple times to build any pressure, it makes 0 sense. When I bled the rear I was able to pull solid fluid, at least one side. There are no leaks yet I can't pull a solid line at the front wheels. F'n baffled.
