Maximum safe boost on a first generation cummins?
#1494746
09/01/13 11:54 PM
09/01/13 11:54 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
With the last round of upgrades to the cummins in my 93 Dodge 1 ton Dooley, It will make 33 pounds of boost. That's about double what it originally made. Am I looking for trouble?
Modifications include a bigger turbo, bigger injectors, turned up VE series pump, four-inch exhaust. What is the most boost that these engines can handle and remain reliable? What are the common failure modes? I have an EGT gauge.
Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Maximum safe boost on a first generation cummins?
[Re: Hemi_Joel]
#1494747
09/02/13 02:59 AM
09/02/13 02:59 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Mine is a 2nd gen and it regularly boosts 40psi, even towing without a problem. I'd say your safe at 33 if you don't let the egt run too hot for too long. If you over boost it, you could end up needed a head gasket.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#1494748
09/02/13 04:19 PM
09/02/13 04:19 PM
Posts: 1,965 ID/MT
Cheeto
ID/MT
This would be a good thread to have for all Gens. I've wondered for quite a while what safe boost is. I have my warning set at 31psi and I hear "her" scolding me quite often.
Cheeto It's not perfect. It's not correct. It's not yours!
[Re: Dragula]
#1494752
10/25/13 02:35 PM
10/25/13 02:35 PM
Posts: 64 Western Pa
Rescue Ram
Western Pa
They estimate 35psi before studs and fire rings and all but each engine handles it differently. My dad had a 94/95 second gen running 40psi without issue. Currently working on a friends 92 first gen and he was seein 28-30 and belching black, i changed so stuff around and what i changed increased his airflow capability and dropped his boost to 22psi WOT and cleaned up his exhaust, still have more to do. I am also building a first gen engine out of a 92 and switch to a ppump and doin alot of other things like twins and i'm setting to try and be around 32psi but making alot of cfm
85 Ram 250 ~ 360 4bbl, 4 speed, 4x4
88 Ramcharger ~ 360 4bbl, Auto, 4x2
09 2500HD SXT ~ 5.7L HEMI, Auto, 4x4, 285/70R17 Courser C/Ts, PowerAid TB Spacer, aFe Full Metal Power, Aero Muffler, 5" side pipes, Hella off-road lights behind grille, Undercover Tonneau, StreetGlow Neons in cab
