Hi I have aquestion on the stud for the header emblem, I found some NOS emblems the foam is cut out in the center so i pulled it out expecting to see threads for a stud but theres only green plastic in the hole, anyone familiar with these emlbems , Im having problems with adding a pic, I just want to know how the original studs were attached to the backside thanks
