Red line tires #149358
11/11/08 04:45 PM
11/11/08 04:45 PM
rochester michigan, oakland co...
drmonday Offline OP
drmonday  Offline OP
I have a 68 Coronet R/T that I have magnum wheeels with P225/60/R15 on the frt. and P255/60R15 on the rear. (which I like)I want to put red lines on it but I can only find them in 70 series
P 215/70R/15 and P235/70/R15. I need some input or
on how much difference this will make,
good or bad or should I go back to 60 series? Any imput will be welcomed!
Re: Red line tires [Re: drmonday] #149359
11/11/08 04:56 PM
11/11/08 04:56 PM
Virginia
JimG Offline
JimG  Offline
Virginia
When you say "a differece", do you mean performance or looks?
If you mean performance, I'd ask about your suspension. Do you have stock .92" (or smaller) torsion bars? Stock rear springs? Aftermarket anti-sway bars? Anything else to increase roll stiffness?
If your suspension is basically stock, I'd say the tires won't become a weak link and cause dramatically worse handling - you possibly won't notice the difference. You didn't say what size 60 series tires you'd be abandoning, but the car might sit slightly higher with 70's, but that's easily fixed.
As for looks, different strokes for different folks - I'll let you decide about that!
Re: Red line tires [Re: JimG] #149360
11/11/08 06:05 PM
11/11/08 06:05 PM
drmonday Offline OP
drmonday  Offline OP
Both in looks and performance. The suspension is completely stock R/T suspension. I know the 70 series is a taller tire but don't know what other differences there are. And or will it handle the same as with the 60 series tires? Which perform fine.
Re: Red line tires [Re: drmonday] #149361
11/11/08 07:07 PM
11/11/08 07:07 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Compared to a 60 series, I can feel a 70 series side wall fold over sooner and they have an overall less precise reaction to steering input - you steer and then have to wait for the tire to catch up and take a set. I wouldn't put anything taller than a 60's sidewall on any car that is going to be driven in a sporting manor.
Re: Red line tires [Re: drmonday] #149362
11/11/08 07:55 PM
11/11/08 07:55 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Diamondback will put a redline on any tire made
Sorry, I don't have there contact info handy
Re: Red line tires [Re: gtx6970] #149363
11/11/08 09:22 PM
11/11/08 09:22 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
www.widewhitewalltires.com
I have their 255/60/15's on all 4 corners
If you want a used set....
Used Set
1MYTGTX
