Page 4 of 4 1 2 3 4
Re: Hemi stumble/sputter on starting line ??? [Re: cudaman1969] #1493495
09/05/13 06:24 PM
09/05/13 06:24 PM
Strongsville, Ohio
Charlie Moore Offline OP
Strongsville, Ohio
Are you running a crank trigger? MSD dist. ? timing locked in at say 35 degrees? I don't think anything is wrong with engine if it runs. Just don't give up, things will work out. We have all been there.
I'm running an MSD trigger and MSD distributor. I can unplug the trigger and plug into distributor and nothing changes. Timing is locked at 31 degrees right now.
Re: Hemi stumble/sputter on starting line ??? [Re: Charlie Moore] #1493496
09/05/13 06:41 PM
09/05/13 06:41 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I was leaning toward rotor out of phase but your heat clue might be the line to follow. Coil (what type) or MSD box could be fine till they warm up. Heat affects wires also, plug and power wires. What size jets in the carbs, could be way to rich after warm
up, kinda like a stuck choke. Where the carbs ever run on another car?
Re: Hemi stumble/sputter on starting line ??? [Re: cudaman1969] #1493497
09/05/13 06:44 PM
09/05/13 06:44 PM
Q
Quicktree Offline
Quicktree  Offline
Q
sounds like another issue other than the carbs
Re: Hemi stumble/sputter on starting line ??? [Re: cudaman1969] #1493498
09/05/13 09:08 PM
09/05/13 09:08 PM
Strongsville, Ohio
Strongsville, Ohio
Coil is a new MSD pro power coil. Ignition wires were replaced, tried 3 different spark plugs. Right now it has 84 and 85 jets. Maybe a bit rich but I wouldn't think it would cause a sneeze back thru the carbs. These carbs were on this car when I bought it in January of 2012.
Re: Hemi stumble/sputter on starting line ??? [Re: Charlie Moore] #1493499
09/05/13 10:11 PM
09/05/13 10:11 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
you did not say what springs you tried to tailor the secondary opening rate too fast is bad!
http://www.summitracing.com/parts/hly-20-13
secondaries that open too fast cause a momentary lean condition which can cause issues like a bog and Pufft!
Re: Hemi stumble/sputter on starting line ??? [Re: Dodgem] #1493500
09/05/13 10:39 PM
09/05/13 10:39 PM
Strongsville, Ohio
Strongsville, Ohio
Dale Cubic had us restrict the secondaries from opening. We actually put accelerator pump springs in so the secondaries would not open. It did not change anything. We have tried several different springs and currently have the strongest spring in right now.
Re: Hemi stumble/sputter on starting line ??? [Re: Charlie Moore] #1493501
09/05/13 11:38 PM
09/05/13 11:38 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Charlie, do you have the 8mm or 8.5 wires on it? Did the 8.5's fit better?
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Hemi stumble/sputter on starting line ??? [Re: sunroofgtx] #1493502
09/06/13 02:00 AM
09/06/13 02:00 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
We never ran any jet bigger than 76. 74to 76 front. Secondary plate opened to approximatey 87 jet, can't remember drill size, this with 426 cubes 12.5 pistons and crane R296 cam. Recently we tried to fire my buddy's 440 and it would backfire through carb and out headers. Found it was a bad msd dist, tried another and fired up and ran great. Don't like electricity or converters because I can't visibly inspect them.
Re: Hemi stumble/sputter on starting line ??? [Re: sunroofgtx] #1493503
09/06/13 07:42 AM
09/06/13 07:42 AM
Strongsville, Ohio
Strongsville, Ohio
I tried the 8.5 wires and nothing changed. I plan on bringing them back to you in a few days. I was also hoping you might have a stock dust boot as I have torn one taking the wires off and on so many times.
Re: Hemi stumble/sputter on starting line ??? [Re: Charlie Moore] #1493504
09/07/13 05:09 AM
09/07/13 05:09 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Have you thought about seeing how it behaves with a single four intake or street Hemi?
That would tell a lot.
Re: Hemi stumble/sputter on starting line ??? [Re: 52savoy] #1493505
09/07/13 05:53 AM
09/07/13 05:53 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Re: Hemi stumble/sputter on starting line ??? [Re: 52savoy] #1493506
09/07/13 07:24 AM
09/07/13 07:24 AM
Strongsville, Ohio
Strongsville, Ohio
Definitely thought of that, but I don't know anyone with a single 4 bbl intake manifold that I could try. And honestly right now I can't afford to purchase one. I could come up with a carb pretty easy.
Re: Hemi stumble/sputter on starting line ??? [Re: Charlie Moore] #1493507
09/07/13 10:13 AM
09/07/13 10:13 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We have a few in stock if you would like to try one.Stop by the shop some day.I don't want to speculate what your problem is but I'am sure you will find the issue.If your at any of the races and we are there just stop by and myself or one of our racers will be happy to help you trouble shoot your problem.
Re: Hemi stumble/sputter on starting line ??? [Re: B G Racing] #1493508
09/08/13 12:10 AM
09/08/13 12:10 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
X2
Your more than welcome to come by my house(shop). Not sure how far off Strongsville is. I have a couple different set-ups you could test.
Fred
Re: Hemi stumble/sputter on starting line ??? [Re: 52savoy] #1493509
09/10/13 07:55 AM
09/10/13 07:55 AM
Strongsville, Ohio
Strongsville, Ohio
Well I pulled the intake off last night and was lucky enough to have the gaskets come intact on the manifold. I showed that the intake is pretty much sitting on the block rails at the front and back. And is about .070 low on the gaskets. It also appears it was not sealing real well across the bottom side of all the runners. It had .060 gaskets when I bought it, so I didn't think much of it. I'm putting .120 gaskets on to raise it up to cylinder head ports. Then were planning on heading to Norwalk. Hope to see you all there.
Re: Hemi stumble/sputter on starting line ??? [Re: Charlie Moore] #1493510
09/10/13 09:27 AM
09/10/13 09:27 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Great news - hopefully this fix will correct the issue and if not there should be enough people there to help sort it out and get it corrected
Russ
Re: Hemi stumble/sputter on starting line ??? [Re: max_maniac] #1493511
09/11/13 01:02 AM
09/11/13 01:02 AM
Ohio
jdfpam Offline
jdfpam  Offline
Ohio
Charlie,
I hope that you found your problem. When you called us, I thought that you said your name was Tony! I did not think that you said Charlie. My Dad thought that the intake gasket could be the problem. Did you leave the cam at 105?
By the way, did you used to race a Ford Fairlane?
Jeff Day
Re: Hemi stumble/sputter on starting line ??? [Re: jdfpam] #1493512
09/11/13 07:37 AM
09/11/13 07:37 AM
Strongsville, Ohio
Strongsville, Ohio
Charlie,
Jeff Day
I now believe the intake was on an engine that had been decked a bit. I needed to raise it up to line up the ports and seal it better. I did leave the cam at 105. Bullet said there was no advance ground into that came and it may work better anyway. I raced a 1963 Ford Galaxie for about 18 years. It is now in southern California.
Thank you to you and your father for listening to my issues and the advise. I will see you this weekend.
Page 4 of 4 1 2 3 4
