Re: What's the best Bendix master cylinder?
[Re: DAYCLONA]
#1493193
08/30/13 01:46 PM
08/30/13 01:46 PM
Posts: 1,247 Fremont, CA.
Topcat
Fremont, CA.
That master you posted is more at home on a B or C body application,....your better of ordering a master for an E body application as the resv. won't be that high
IIRC your doing an offset HEMI Bendix booster on your E body?....is the "numbers correct" master important? ($$$$$), or just somewhat correct in appearance, but functional as well?
If I was choosing one for a HEMI E body application using a HEMI Bendix booster, appearance wise and function wise for a power disc/drum application I would use a Fenco pn# M1628...readily available from any part store that carries the Fenco line....It's also available in the Cardone and NAPA system under 10-1628
mike
Thanks Dayclona. OEM appearance on it would be nice. But not a $1,000 nice worth doing. I'll check into getting the one you recommend.
[Re: Topcat]
#1493194
08/30/13 08:16 PM
08/30/13 08:16 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Mike, here's the M1628....personally I'd use Fenco or NAPA, Cardone as a rebuilder of used and supplier of new masters is a 50/50 shot at best of getting the 1. correct master, and 2. a working unit
[Re: DAYCLONA]
#1493196
08/30/13 10:49 PM
08/30/13 10:49 PM
Topcat
Fremont, CA.
Here's the real deal, in fit and correct OEM appearance
thanks Dayclona
It looks very close to the one in the picture I showed above. From what I gathered from Ramman's website is: The E body version is 7/10" lower in height to get the hood clearance.
However I'm not an expert on bendix master cylinders so take it with a grain of salt.
He sells clones for $450. I would rather put money right now into getting the car rolling/running right now and perhaps upgrade it to either modified or correct at a later time.
[Re: Topcat]
#1493197
08/30/13 11:37 PM
08/30/13 11:37 PM
Topcat
Fremont, CA.
I noticed the lid is different on the Raybestos and the OEM BTW. Are those available?
[Re: Topcat]
#1493198
08/31/13 12:33 AM
08/31/13 12:33 AM
Posts: 18,157 Mass
DAYCLONA
Mass
What do you mean?...
[Re: can.al]
#1493201
08/31/13 10:37 PM
08/31/13 10:37 PM
Posts: 18,157 Mass
DAYCLONA
Mass
..make sure the master cylinder piston size is appropriate. ..but i'm sure you have thought of this.
Yes, the master 1628 I recommended to Topcat is actually for a 71 E body application (also fits 72-4) using factory power assisted front discs and rear drums for a B engine application, it has an 1 1/32 bore....the factory correct HEMI master has a 1 1/8" bore, stroke is relatively the same
