A body Kelsey hayes discs #1493141
08/30/13 10:56 AM
08/30/13 10:56 AM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
is the transfer tube on the A body Kelsey 4 piston calipers
a standard 6 or 7 inch brake line and fittings.
i'm rebuilding my calipers and would like to replace them.
Re: A body Kelsey hayes discs [Re: can.al] #1493142
08/30/13 11:33 AM
08/30/13 11:33 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Where are you getting your rebuild parts? I've got some that need rebuilding too. I see Advance has seal kits for $9.99 but I assume you need 8 kits for both calipers?
I was going to soak my transfer tubes in EvapoRust and see how they come out. I could have them zinc plated with the rest of the hardware when that time comes.
Re: A body Kelsey hayes discs [Re: burdar] #1493143
08/30/13 11:43 AM
08/30/13 11:43 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
One kit does one caliper, BUT you need to make sure it has the correct dust shields. There were two kinds, early and late. The early seals go around a lip on the caliper while the later seals go into a groove above the o-ring groove. Since these are the same kits as 65-67 Mustangs (and, I suspect, they only use the early seal) some kits only have the early seals.
Re: A body Kelsey hayes discs [Re: can.al] #1493144
08/30/13 11:48 AM
08/30/13 11:48 AM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
You can buy New hard lines on the calipers from Fine Lines.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: A body Kelsey hayes discs [Re: hemi71x] #1493145
08/30/13 11:51 AM
08/30/13 11:51 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The picture on Advances website only shows one seal and one dust boot...that's why I assumed you needed 8 kits for both calipers.
Re: A body Kelsey hayes discs [Re: burdar] #1493146
08/30/13 12:39 PM
08/30/13 12:39 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..Mine are in good shape.The only difficult part was removing the pistons which are now all out and being stainless polished up like new.
.i have taken the transfer tubes off now and will check
these at my local auto parts store,or if necessary order from 'fine lines'
..tx guys.
Re: A body Kelsey hayes discs [Re: can.al] #1493147
08/30/13 03:04 PM
08/30/13 03:04 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..just checked and the transfer lines are standard brake lines and fittings.
Re: A body Kelsey hayes discs [Re: can.al] #1493148
08/30/13 07:45 PM
08/30/13 07:45 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
here's the lines you need the right stuff brakes
http://www.getdiscbrakes.com/partfinder/product/list/?year=1970&make=Chrysler,%20Dodge,%20Plymouth&model=A%20Body%20-%20Barracuda,%20Dart,%20Duster,%20Valiant&category=Brake-Lines&cat=1254
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
