904 Trans question #149313
11/11/08 12:57 PM
11/11/08 12:57 PM
Long Island, NY USA
BergmanAutoCraft Offline OP
Long Island, NY USA
Took my 904 out for some detailing and a 6K governer weight. Checked the bands, adjusted the rear to 4 turns, front to 2 turns (4.2) lever (B &M Transpak). Put the deal back in, and ....
P, R , N all fine. Put it in D or 2 it feels like its in high gear. Pull down to 1st and it takes off fine. However, it will shift into 2 or 3 from first like a man valve body.
Did I screw up the giverner weight somehow? This was a working trans before. Any advice?
Re: 904 Trans question [Re: BergmanAutoCraft] #149314
11/11/08 01:17 PM
11/11/08 01:17 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
I have always set my second gear bamd at 1 1/4 to 1 1/2 turns. Mostly 1 1/2 turns except for one trans that didn't want to shift into second gear.
Re: 904 Trans question [Re: babarracuda] #149315
11/11/08 01:22 PM
11/11/08 01:22 PM
Kunkel are you awake yet
Re: 904 Trans question [Re: RapidRobert] #149316
11/11/08 01:23 PM
11/11/08 01:23 PM
Long Island, NY USA
Long Island, NY USA
I'm thinking the governer weight I put in may be wrong somehow...
Re: 904 Trans question [Re: BergmanAutoCraft] #149317
11/11/08 01:30 PM
11/11/08 01:30 PM
The only thing you did was adj the bands & ch the gov weight? the valve body was not gone into(on this deal)?
Re: 904 Trans question [Re: RapidRobert] #149318
11/11/08 03:53 PM
11/11/08 03:53 PM
Long Island, NY USA
Long Island, NY USA
Not at all.
Re: 904 Trans question [Re: BergmanAutoCraft] #149319
11/11/08 04:12 PM
11/11/08 04:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Taking off in a gear other than 1st is a governor problem, if the governor pressure is too high at a standstill the trans will think it's traveling at road speed and shift to a higher gear.
Go back into the tailhousing and check the governor installation, be sure the valve and weight are free to move.
Re: 904 Trans question [Re: John_Kunkel] #149320
11/11/08 04:46 PM
11/11/08 04:46 PM
Long Island, NY USA
Long Island, NY USA
Will do, thanks for the advice.
Re: 904 Trans question [Re: John_Kunkel] #149321
11/11/08 07:24 PM
11/11/08 07:24 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
100%even the smallest particle of dirt or lint can hang them up.damhik
