Page 10 of 14 1 2 8 9 10 11 12 13 14
Re: Cam break in is done!....Now more questions! [Re: Kern Dog] #1493004
09/14/13 12:18 AM
09/14/13 12:18 AM
When you swap head gaskets I'd take a few CC's out of the combustion chambers also. I think you can come out of this alright
Re: Cam break in is done!....Now more questions! [Re: RapidRobert] #1493005
09/15/13 03:21 AM
09/15/13 03:21 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
I almost had the heads hogged out in 2006 when I installed those Cometic .060 head gaskets. The man I spoke with wanted $1000 to port the heads and remove 4 ccs from each chamber. It seemed like a lot back then, but now it seems somewhat reasonable.
Re: Cam break in is done!....Now more questions! [Re: Kern Dog] #1493006
09/15/13 11:43 PM
09/15/13 11:43 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I just ordered the Mallory spring kit from Summit. Dodgem posted the link a few posts ago. For $35, its worth a try.
Rick Ehrenberg from Mopar Action likes the use of a two stage timing curve. The instructions on the Mallory packaging show how to achieve this.
Maybe by Wednesday I'll be able to work on the spare distributor and get it in the car. I'll have to drive the car around to use up the high octane gas I have in it now. At 6-7 mpg, that shouldn't take too long!
Re: Cam break in is done!....Now more questions! [Re: Kern Dog] #1493007
09/16/13 11:21 AM
09/16/13 11:21 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Yea think your on the right track get a nice idle advance but slow it down to total maybe all in by 3500?? Give or take.
I still wonder about intake gasket glowing??
Good luck
Re: Cam break in is done!....Now more questions! [Re: RapidRobert] #1493008
09/16/13 03:04 PM
09/16/13 03:04 PM
California
mickm Offline
mickm  Offline
California
My comment was in jest but yes a bit facetious & Franken is one of the good guys (on here). I am following this thread closely also & we will get resolution. I'm thinking it's gonna take MORE octane or a piston change & all that goes with that. when you build a monster it needs to be fed properly, no other way around it
robert, my comment about not taking it all too seriously was all the suggestions that FBO made...
just to clear that up!
Re: Cam break in is done!....Now more questions! [Re: 67Satty] #1493009
09/18/13 11:15 PM
09/18/13 11:15 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Isn't decking your block that much to get your pistons up to zero deck going to open up another can of worms? Or are you talking about new pistons?
Hey Satty,
Dwaynes idea was to get to zero deck to close up the quench, but at the same time have the valve sides of the pistons milled about .040. This milling would cover about 2/3 of the piston, so calculating compression off of that wouldn't be too hard. The effect that Dwayne was speaking of was a huge gain in quench with a similar volume in the combustion chamber. This would likely result in a similar CR and cranking compression numbers. The expected gain was in quench while still maintaining the power of higher compression.
***Today I mapped the spark curve as it sits in the car. As expected, the 14 degrees of mechanical advance really is all in by 1900-2000 rpms. This distributor had 2 pink advance springs and the tabs were bent out to tighten up the spring tension. I had full advance long before the converter stall speed.
I took my spare distributor and installed 2 orange springs. The curve appears similar but comes on a bit later. The total advance isn't reached until about 2500. I ran the car to test the curve but I didn't drive it. I need to use up the high octane 110 Sunoco that is still in the tank.
I took the first distributor from the car that had the 2 pink springs and changed to 2 brown springs. Some experts suggest using a purple spring and one of another color to have a 2 stage advance. Until I can make sure that it will not detonate at 31 degrees, 32 degrees or so, the 2 stage curve is pointless. My 14 degree advance is short enough to just have a single stage curve.
Re: Cam break in is done!....Now more questions! [Re: Kern Dog] #1493010
09/19/13 01:07 AM
09/19/13 01:07 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
You may even want to slow it down to have the total in at 3000 or 3500 ??
Re: Cam break in is done!....Now more questions! [Re: Dodgem] #1493011
09/19/13 01:30 AM
09/19/13 01:30 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I thought so too. I'd need to look for stiffer springs than what came in the Mallory kit.
If anyone knows any tricks for tuning distributors, I'm willing to learn!
Re: Cam break in is done!....Now more questions! [Re: Kern Dog] #1493012
09/20/13 01:24 AM
09/20/13 01:24 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I'm still looking at different head gaskets to lower the CR.
The Cometic .075 ones lower the CR to 9.89. That would buy me a lot of octane forgiveness, but I wonder if I need to go that low. They are pricey...$143 each.
These are from Flatout:
http://www.summitracing.com/parts/fog-900464520
They have a 4.520 bore and a .064 thickness. They would lower the CR to 10.11. They are also $176 for a pair.
The .060 Cometics I used in 2006 lowered the CR to 10.29. The engine didn't ping with those, and that was with the distributor that had the fast advance curve.
The Flatout .064 gaskets are tempting. the 10.11 CR looks like it would get me a little wiggle room in case I got a mediocre batch of gas or if the weather was really hot.
Re: Cam break in is done!....Now more questions! [Re: Kern Dog] #1493013
09/20/13 10:10 AM
09/20/13 10:10 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If I could go back and visit myself in 2004 I would have ordered dished pistons and zero decked the block. This would have put me in the mid 9s with quench. I probably could have run 87 octane while still making plenty of power.
I could still do this, but that would be another $1000 in parts, machine work and down time.
You could do it with a semi custom Diamond piston , this is assuming the decks were squared in the original build.
Re: Cam break in is done!....Now more questions! [Re: JohnRR] #1493014
09/20/13 12:27 PM
09/20/13 12:27 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Does this thing rattle no matter whose gas is in it? It is not unheard of that regular gets dumped in the premium tank either by accident or design. If you always gas up at the same place, go somewhere else preferably a brand name station.
Make sure it isn't still sucking oil thru the intake. I would hold off on the thick gaskets because the loss of quench will likely hurt more than help. We're missing something here because there are lots of guys here running similar combos without having to resort to race gas.
Kevin
Re: Cam break in is done!....Now more questions! [Re: Twostick] #1493015
09/20/13 10:26 PM
09/20/13 10:26 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
In summary, the 10.7 CR detonated on 91 octane when I had the MP 292/509 cam. I changed to 1.6 rocker arms, bumping the lift to .543 and while it ran a bit smoother, it still knocked. I added 110 Sunoco to a half tank of 91 and the knocking stopped. All along I have wanted to be able to run this engine on 91 octane or less. I asked questions here and elsewhere about what options there are to get there. I took the advice of a guy on another site on the Lunati solid cam I have in the car now. Well, that cam looked great on paper but somehow made things worse. I can still get it to stop knocking with 110 fuel, but that still leaves me miles away from the original goal.
I have tried UPjetting and DOWNjetting the carburetor.
I have tried another carburetor.
I have tried timing adjustments, different distributors, colder spark plugs, new wires, early day (For cooler weather) and the car still knocks at WOT with anything less than the current mix of 110 and 95 octane fuel. I did change the advance springs in the distributor, but all that did was delay the advance by about 400 rpms. Thats not enough to help.
I do not know if the block decks are square. That is an interesting point. I suppose that it is possible to have one or more pistons sitting higher or lower than #1 at TDC. I do know that with #1 piston .017 in the hole and with the .039 head gasket, I am at .056 for quench. I've asked it before and most people seem to think that at that distance, the beneficial effects of quench are minimal if any. It is because of this that I have considered using the thicker head gaskets again.
Regarding the possibility of getting a bad batch of gas or gas labled as 91 that is really 87: I thought of that, but the car has been pretty consistant. I live in Northern CA and have driven the car to LA and back 3 times. I have been dealing with this same problem for years. It is just this year that I have had some $$$ to spend to fix it.
The valley pan has been clean and dry since I replaced it a few weeks back. Looking back at my notes, I found that when replacing the valley pan in the past, I have alternated between using the tin alone as well as using the paper gaskets. I'm embarrassed to admit though that I had the intake manifold torque spec way off. I was only cranking it to just past 12 lbs because I incorrectly thought I read that in the Edelbrock instructions.
This engine has no blowby. The cranking compression numbers are within 4% from highest to lowest. It got closer when I put in the adjustable rockers, probably because the stock type rockers were inaccurate.
Re: Cam break in is done!....Now more questions! [Re: Kern Dog] #1493016
09/21/13 12:07 AM
09/21/13 12:07 AM
Fact: You want it to run strong on 91 (fast curve). You have little/no quench. (1) pick the cam YOU want (2) Pick a head gasket(s) that will get the SCR down to where the DCR will not ping on 91 & let you run a fast curve. (3) dial in the dist. Taking some CC's out of the heads will let you not have to go so thick on the gaskets as either way you will have to deal with thicker intake gaskets likely required to make everything line up. Just me if the pistons are high enough to where I could get quench with the right thin gasket I'd mill some reliefs in the piston decks & the heads to lower the SCR then rebalance the crank or possibly heavier pins to make up for what you took off the pistons & as said you can take a "significant" amount off of the pistons before rebalancing is required especially with them being aluminum. If the piston deck is .150" or thicker you are OK. IMNHO no way is quench by itself going to take care of the SCR being that high with crap gas plus you dont have the cam you'd like. I dont think you want to go back into the shortblock so dont take my ramblings in the 2nd half of this serious
Re: Cam break in is done!....Now more questions! [Re: RapidRobert] #1493017
09/21/13 12:30 AM
09/21/13 12:30 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
IMNHO no way is quench by itself going to take care of the SCR being that high with crap gas plus you dont have the cam you'd like. I dont think you want to go back into the shortblock so dont take my ramblings serious
I like your way of thinking.
For the most part, I am okay with this cam if the engine didn't knock. The idle is decent and with 110 fuel, it runs stronger than it ever has. I expect it to run even better with more spark advance once I lower the CR. It isn't quite as snappy from a start as the 509 but sure feels stronger from the midrange and up.
Maybe I am asking for more than the engine can give. I like the idea of having serious low and midrange power, but doesn't that often mean using a cam that builds more cylinder pressure? The only reason I went with the Lunati solid was to reduce cylinder pressure. THAT totally backfired. I've had trouble finding accurate specs on the Mopar 509 cam intake closing point. The site below shows the specs but I'm not confident that they tell the whole story:
http://victorylibrary.com/mopar/mpcam-tech-c.htm#b
Months ago when I was looking at a cam swap as a cure, the only user-friendly online dynamic compression ratio calculator I could find was from Kieth Black. The section where you enter the intake closing point asked for the actual number on the cam card, plus 15 degrees. My Lunati card shows 56.5, add 15 degrees and it comes to 71.5. The link above shows what may be a "gross" number of 74 degrees for the 509 cam. Maybe this is similar to how MP refused to list the @ .050 cam duration for so many years.
IF the MP 74 degree number is an accurate spec, this means that the "bigger" Lunati cam actually has an earlier intake closing. This is likely to be true since the cranking compression went UP by an average of 3 psi per cylinder after installing the Lunati cam.
I agree that while quench may be helpful, I just can't see how going UP in compression to get quench would work out for me.
IF I were somehow able to maintain the same CR while improving quench, I could see that maybe being effective.
Re: Cam break in is done!....Now more questions! [Re: Kern Dog] #1493018
09/21/13 12:44 AM
09/21/13 12:44 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Tighten the intake valve lash .01-.015" and see if it helps. I'm not going to go back through all this but from the start I can see the problem and this is a crutch.
Re: Cam break in is done!....Now more questions! [Re: Kern Dog] #1493019
09/21/13 12:47 AM
09/21/13 12:47 AM
(1) I think the scr is too high & the gas (91) too poor to avoid pinging even with good .040" quench. (2) unfortunately that would take a piston change. Decades ago HotRod magazine did a build on a 454 chebby iirc work truck & they vastly increased the mileage & the tradeoff was it lost some power either low or midrange I dont remember & not sure if there was a pinging issue but I think the CR was too high also. I'd call a cam company & ask if that is feasible. It'd be 10 minmutes well spent. Unless they can grind a special cam I think it's gonna take lowering the scr with thicker gaskets & I'm sure a regular cam ain't going to fix this either
Re: Cam break in is done!....Now more questions! [Re: RapidRobert] #1493020
09/21/13 12:50 AM
09/21/13 12:50 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
tightening the intake vl will close the intake much later and give a clue as to the chance he might get away with a poor combo. Simple stuff.
Re: Cam break in is done!....Now more questions! [Re: goldmember] #1493021
09/21/13 01:02 AM
09/21/13 01:02 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
This makes sense too. Jim at Racer Brown suggested the same thing.
Re: Cam break in is done!....Now more questions! [Re: Kern Dog] #1493022
09/21/13 01:03 AM
09/21/13 01:03 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
No suprise at all.
Re: Cam break in is done!....Now more questions! [Re: Kern Dog] #1493023
09/21/13 01:04 AM
09/21/13 01:04 AM
Columbus Ohio
mopfried Offline
mopfried  Offline
Columbus Ohio
Im probably all wrong about this, but wouldnt a bigger camshaft make more cylinder pressuer at a higher RPM compaired to a smaller camshaft? I have thought about your build and read all the posts over and over. I am having a similar problem with my standard bore, standard stroke 440. I have 452 heads milled around .100 to make them closed chamberd. I have no quench. Im running a Comp 284XE cam with 1.6 rockers. I just hooked up the wide band and its rich except WOT. I think I need larger jets in the secondarys and a smaller number on the power valve. Anywhay, Not trying to hyjack your thread, but would the more duration, higher lift cam make more cylinder pressure at a higher RPM? If not how does it make more HP? It holds the valves open longer to let MORE air in... at a low RPM it bleeds it off...
