Re: Is there a 5.9 magnum carb intake that has a/c bolt up?
[Re: Andrewh]
#149291
11/11/08 01:53 PM
11/11/08 01:53 PM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
If your using the magnum accesories, just about any magnum intake sould work with a little fiddling. I am working on using a Offy dual quad intake on a magnum motor with all the accy's including a/c. I am using a van bracket which has a shorter compressor, but this is needed to clear the first carb.
I believe the only true plug and play manifold in the carb setup is the dual plane M1. The braces off the top of the magnum bracket are not needed, there is plenty of meat in that a/c / alt bracket to keep it steady. I have had zero trouble with mine thus far.
Outcast Dodge guy.
[Re: Andrewh]
#149293
11/11/08 04:26 PM
11/11/08 04:26 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I'd suggest contacting board member Jerry and have him build up a megasquirt computer and harness for ya...
