Hood Clearance issues - 70 Cuda #1492162
08/28/13 10:35 PM
08/28/13 10:35 PM
Kingston, Ontario
70GranCoupe Offline OP
Kingston, Ontario
I have a 440 with a 750 Holley and a street dominator intake topped with a shaker assembly. I am short about 1/2 for clearance.
Other than change out the intake is there anyway I can get more clearance under the hood to get this setup to work. Is there such a thing as low profile engine mounts?
Appreciate any suggestions.
Re: Hood Clearance issues - 70 Cuda [Re: 70GranCoupe] #1492163
08/28/13 10:42 PM
08/28/13 10:42 PM
USA
K
krw71ragtop Offline
krw71ragtop  Offline
K
USA
I think moparts member paint it black has the low profile air cleaner base you need.
Re: Hood Clearance issues - 70 Cuda [Re: 70GranCoupe] #1492164
08/29/13 12:43 AM
08/29/13 12:43 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
That would screw up your driveling angle, but never heard of such a thing.
You will need to somehow make a drop base out of your shaker baseplate.
Re: Hood Clearance issues - 70 Cuda [Re: 70GranCoupe] #1492165
08/29/13 12:55 AM
08/29/13 12:55 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
have you thouhht about putting a 1/2 " spacer between the frame and K member?
Re: Hood Clearance issues - 70 Cuda [Re: calrobb2000] #1492166
08/29/13 10:47 AM
08/29/13 10:47 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
I dropped the K 1/2" in my Cuda for the same reason. I then had to cut 1/2" out of the tranny mount. It all took a little while but was not that big a deal.
There might be 3 ways to approach this; machine the carb flange on the intake down, fab in a drop base air cleaner, or drop the K. Whick one do you feel is easier for you?
Master, again and still
Re: Hood Clearance issues - 70 Cuda [Re: DaveRS23] #1492167
08/29/13 12:29 PM
08/29/13 12:29 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Be aware if you drop the base too far it can cause the lid to restrict the air flow into the carburetor leading to a loss of power at upper RPMs
I would swap the intake before moving the engine, k frame etc
Re: Hood Clearance issues - 70 Cuda [Re: 70GranCoupe] #1492168
08/29/13 01:24 PM
08/29/13 01:24 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Which single Shaker 4 bbl base are you using?, there's 3 different factory height 4 bbl bases....
Re: Hood Clearance issues - 70 Cuda [Re: DAYCLONA] #1492169
08/29/13 03:21 PM
08/29/13 03:21 PM
Kingston, Ontario
Kingston, Ontario
I have 1 5/8" from the bottom of the throat to the bottom of the bridge for the carb stud. This should be good.
I also see that my radiator, fan and fan shroud do not match up by about 1/2" so the engine seems to be sitting a bit high.
My first attempt will be to see if I can put spacers between the K-frame and the frame to see if this makes a difference.
Other than raising the profile by 1/2" is there any reason why this should not be done.
Thanks.
Re: Hood Clearance issues - 70 Cuda [Re: 70GranCoupe] #1492170
08/29/13 05:32 PM
08/29/13 05:32 PM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
Thanks.
I am curious ,you think the spacers between the frame and the K member would effect the suspension and over balance of the car?
Re: Hood Clearance issues - 70 Cuda [Re: 70GranCoupe] #1492171
08/29/13 10:58 PM
08/29/13 10:58 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Thanks.
Something is wrong, Mounts, brackets K frame, dunno sounds like you want the easy way out rather than the correct way, Bubba says yeehaa, we do it all the time at the local circle jerk track. Sorry Fix the root cause rather than afro engineering it. Sorry again another long day week of dealing with Bubbafied fixes that don't work
