70 Superbee wiring #1492007
08/28/13 01:13 PM
08/28/13 01:13 PM
Troy,MI
Siba Offline OP
Siba  Offline OP
Troy,MI
Trying to help a friend figure out this wiring. Figured Moparts could answer. This is behind the drivers side kick panel.
Re: 70 Superbee wiring [Re: Siba] #1492008
08/28/13 04:51 PM
08/28/13 04:51 PM
1970_EK2AAR Offline
1970_EK2AAR  Offline
These are the connections used on a '70 Charger for the hide-away headlight power relay. So in your case . . . not needed.
Re: 70 Superbee wiring [Re: 1970_EK2AAR] #1492009
08/29/13 08:29 AM
08/29/13 08:29 AM
Troy,MI
Siba Offline OP
Siba  Offline OP
Troy,MI
Thank you
