power brake booster push rod adjustment tips anyone? #1491886
08/28/13 05:53 AM
08/28/13 05:53 AM
Charleston, SC
bronco9588 Offline OP
Charleston, SC
I just upgraded to a rebuilt brake booster and master cylinder. The master cylinder came with a spacer that allows the booster to ventilate. It seems like a good part to use. Anyways, that spacer sets the master cylinder about a 1/4" more forward and really is stretching the amount of usable threads on the push rod adjustment. Current pedal travel is about 1/2" before push rod engages the master cylinder. Is there a location that I can buy a longer threaded acorn piece? Is there a travel spec for the car in my signature?
I don't see much of a better way than to use trial and error in setting the push rod distance. Do I need the engine running to maintain vacuum on the booster? Thanks for your help!
'73 Charger Petty Blue, Black Vinyl, and Gill Slits 727 torque-flight 400 BB Chrysler 8 3/4 rear
Re: power brake booster push rod adjustment tips anyone? [Re: bronco9588] #1491887
08/28/13 11:18 AM
08/28/13 11:18 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Why would you want to ventilate the master?They have been bolted to the booster for 60 years.I set the rod so its about 1/16 inch from the piston.My kids 300 has been on for 15 years and no problems even with big tube headers.Rocky
Chrysler Firepower
Re: power brake booster push rod adjustment tips anyone? [Re: therocks] #1491888
08/28/13 11:34 AM
08/28/13 11:34 AM
Andrewh Offline
Andrewh  Offline
if you find a way to extend the rod, what I did was look into the master cylinder as I push it onto the booster.
there is a hole at the bottom where you can see the piston.
I just watched it as I pushed it flush. I extended the adjustment out enough that I could see the piston move, then backed it off till it didn't move any more when I pushed the master on flush.
Re: power brake booster push rod adjustment tips anyone? [Re: Andrewh] #1491889
08/28/13 11:44 AM
08/28/13 11:44 AM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Had these instructions in my reman booster.....
1MYTGTX
