Re: Dana 60 rear backing plates
[Re: MOPARS6768]
#1491211
08/26/13 11:47 PM
08/26/13 11:47 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Just buy the disc brake brackets for about $50 then go to the parts store and get the front rotors for an 84 K20 and a pair of 84 chevy calipers. You can do the disc brake swap for as much, or slightly less than redoing a drum brake setup (if you are replacing drums) http://www.ebay.com/itm/290908146515?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649Rockauto has the rotors and loaded calipers for about $90 plus core charges. A local parts store should be about the same.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
