Making some progress #1491187
08/26/13 04:14 PM
08/26/13 04:14 PM
Las Vegas
Al_Alguire Offline OP
Las Vegas
Well we finally got the truck back on the ground yesterday. Made new trans crossmember for the 727 and also fabbed up some bracing for front crossmember we had to cut for the trans to fit. Will be boxing in frame and tying the front member into that soon. Need to find a slip yoke so I can get a driveshaft made for it. Pull the tranny to put the flexplate in converter in the trans and trans back in so we can work on the shifter. Flipped the rear axle, notched the frame and boxed all that in. We will keep plugging away at it. Not looking to spend a lot of this thing and so far so good. Just some steel and time. Here is a bad pic I took after getting it on the ground.
Re: Making some progress [Re: Al_Alguire] #1491188
08/26/13 04:19 PM
08/26/13 04:19 PM
East Texas
Mopar2DBone Offline
Mopar2DBone  Offline
East Texas
Love the Swepts... Nice house too...
Re: Making some progress [Re: Al_Alguire] #1491189
08/30/13 11:27 PM
08/30/13 11:27 PM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
Nice Truck ....More pictures of the truck and the HOUSE!!
Re: Making some progress [Re: Al_Alguire] #1491190
08/31/13 02:57 PM
08/31/13 02:57 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Looking good Don't leave it outside too long, the Count might show up and want to buy it
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Making some progress [Re: Silver70] #1491191
09/01/13 12:58 AM
09/01/13 12:58 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I told Al to put a hoodie sleave on his head and start his own Las Vegas show....
for now we'll have to settle for "over-Al-in"
Re: Making some progress [Re: J_BODY] #1491192
09/01/13 03:54 AM
09/01/13 03:54 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The Wages and Perks from being a Moparts Moderator must be great.
Re: Making some progress [Re: Webster] #1491193
09/01/13 03:34 PM
09/01/13 03:34 PM
Las Vegas
Las Vegas
Well as J knows the truck has assumed it's usual location for now. I need a driveshaft and this is certainly project low buck. SO until I can locate a slip yoke or complete driveshaft it will again be sitting for awhile again. Hopefully I can locate a yoke or complete shaft soon.
Re: Making some progress [Re: Al_Alguire] #1491194
09/01/13 08:51 PM
09/01/13 08:51 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Wonder what shaft would be close? 8.75 small ujoint set up in there?
Re: Making some progress [Re: J_BODY] #1491195
09/01/13 09:56 PM
09/01/13 09:56 PM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
Not positive, but a c body shaft would have the 727 yoke, and a mid 70s one, or all I've ever had , had the small u joint. Would be long enough, just shorten it.
Love the sweptlines!
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: Making some progress [Re: old_goat] #1491196
09/02/13 01:32 PM
09/02/13 01:32 PM
Las Vegas
Las Vegas
Yep small joint 8 3/4. If I could locate a yoke I think I can just have the old 4 speed shaft shortened and use it?
Re: Making some progress [Re: Al_Alguire] #1491197
09/02/13 01:47 PM
09/02/13 01:47 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
front slip yoke? or the rear yoke? I've got a small joint 727 slip yoke.....somewhere. Might be fun finding that one!
Re: Making some progress [Re: J_BODY] #1491198
09/03/13 01:57 PM
09/03/13 01:57 PM
Las Vegas
Las Vegas
Slip yoke..The original driveshaft for the 4 speed uses a different slip yoke and is longer than what is needed for an auto. If i had a slip yoke could get the stocker shaft shortened.
