Summit Racing rebuilt thermoquad #1491003
08/26/13 08:53 AM
08/26/13 08:53 AM
georgia
mopa Offline OP
mopa  Offline OP
georgia
Has anyone used a rebuilt thermoquad carb from Summit Racing and did it work well?
Re: Summit Racing rebuilt thermoquad [Re: mopa] #1491004
08/26/13 11:05 AM
08/26/13 11:05 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I don`t know what rebuilt brand the Summit carbs are but I bought a rebuilt thermoquad from NAPA and it worked fine.
Re: Summit Racing rebuilt thermoquad [Re: mopa] #1491005
08/26/13 11:21 AM
08/26/13 11:21 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Problem with rebuilds is they usually don't bush the throttle shafts.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Summit Racing rebuilt thermoquad [Re: Rug_Trucker] #1491006
08/26/13 01:33 PM
08/26/13 01:33 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Yup. So far two 'rebuilt' carbs from commercial companies both of them didnt even bother to pull the throttle plates and shaft before sandblasting everything. Go to pull them after the fact and you could see the rust on the hidden surfaces.
Re: Summit Racing rebuilt thermoquad [Re: 135sohc] #1491007
08/26/13 02:20 PM
08/26/13 02:20 PM
P
Paul_Fancsali Offline
P
The majority of parts store rebuild carbs are very questionable I myself would rebuild what I have or go to q Rochester Q jet unless restoring. The majority of TQ's are questionable I know I have a half dozen sitting that I obtained in early 80s and even then throttle shafts were issue avoid real heavy return springs
Re: Summit Racing rebuilt thermoquad [Re: mopa] #1491008
08/26/13 07:15 PM
08/26/13 07:15 PM
Puttin' on the foil in Charles...
not_a_charger Online mad
Mr. Big Shot Moparts Moderator
not_a_charger  Online Mad
I looked into getting one, but for not too much more $$$, I got a COMPLETELY restored TQ from Scott Smith, and it not only worked flawlessly right out of the box, but it's a work of art, too.
My ...spend a few extra bucks and get a carb that you know will be exactly right. Scott's reputation is stellar for a reason.
Earning every penny of that moderator paycheck.
DBAP
