Re: Need new oil pan for 65 coronet with 426 Hemi!
[Re: BB65Barracuda]
#1490972
08/27/13 09:49 PM
08/27/13 09:49 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
Stock 1966 Mopar. Do you think if I hang or remove the K member I will be able to swap it out? I really don't want to raise the car up.
What block do you have MP or World ? World blocks have an adapter that bolts in so no K removal would be required.
But if you pull the K you shouldn't have any issue unscrewing the pickup.
[Re: feets]
#1490977
08/28/13 09:33 AM
08/28/13 09:33 AM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
You've got the chance to make it a streetable car now. Sadly, if you built that engine correctly with a pickup hanging down to the bottom of the pan the engine will need to come out to swap the pick up tube for a shallower unit.
How many people do you know that would build a motor and install the wrong pickup?
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
[Re: ZIPPY]
#1490979
08/28/13 11:12 AM
08/28/13 11:12 AM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
Just remember that you will need a new 1/2 inch pickup.Most with stock pans are 3/8.A hemi pan should have a 1/2 inch.Rocky
Chrysler Firepower
[Re: therocks]
#1490981
08/28/13 12:54 PM
08/28/13 12:54 PM
JohnRR
U.S.S.A.
The pan he wants to switch to probably uses the same pickup that is there now ....
[Re: BB65Barracuda]
#1490985
08/28/13 04:20 PM
08/28/13 04:20 PM
Posts: 5,160 Texas
dannysbee
Texas
Sure it will. It's a max wedge pan. Better carry your check book of you find one.
Getting old just means you were smarter than some and luckier than others.
[Re: dannysbee]
#1490986
08/29/13 07:37 AM
08/29/13 07:37 AM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
Are you certain? I have the Schumacher mounts on my car and it is not listed in their add. If it will I found a Milidon pan that is a Max wedge Replacement. Pretty Cheap to!
[Re: BB65Barracuda]
#1490987
08/29/13 08:10 AM
08/29/13 08:10 AM
JohnRR
U.S.S.A.
Are you certain? If it will I found a Milidon pan that is a Max wedge Replacement. Pretty Cheap to!
No you won't, there isn't one.
Milodon makes those deeps sump pans or the road race pan that will require you to modify the K frame .
6qt hemi pan , pull the K frame and nothch it for pan clearance and add a skidplate from a 67-69 hemi car.
[Re: 62maxwgn]
#1490991
08/29/13 12:07 PM
08/29/13 12:07 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
I measure the pan and its around 15" from the back of the pan to the front of the sump. The Guy at Schumacher said he had not tried the 30761 but if the rear of the pan to the front sump clearance is 18 or less it will work in my 65 B Body with their Hemi conversion mounts. I called Mancini and they pulled one for me so we will see this weekend. I'll pick it up and try the install and will post results. If it works out the pan and Pick up with a good Gasket is only $220.00 at Mancini. Hopefully we will be back on the road this weekend.
