correct brake booster and master cylinder? #1490939
08/26/13 02:19 AM
08/26/13 02:19 AM
Can someone help me with a picture of what the correct power brake booster and master cylinder would be for a 69 GTX with power drum brakes?
Re: correct brake booster and master cylinder? [Re: ] #1490940
08/26/13 11:17 AM
08/26/13 11:17 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I should read more carefully, this is in a 70 GTX but what your after is the same.
Re: correct brake booster and master cylinder? [Re: ] #1490941
08/26/13 01:59 PM
08/26/13 01:59 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Brake booster would be a 5/16 studded bendix.
MLR426
Re: correct brake booster and master cylinder? [Re: MLR426] #1490942
08/26/13 02:03 PM
08/26/13 02:03 PM
fargo,nd
fk5hemi Offline
fk5hemi  Offline
fargo,nd
I thought the power DRUM brakes used the midland-ross booster.
Re: correct brake booster and master cylinder? [Re: fk5hemi] #1490943
08/26/13 02:15 PM
08/26/13 02:15 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
You are correct.
Power DISC Brakes, used the Bendix Booster.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: correct brake booster and master cylinder? [Re: ] #1490944
08/26/13 02:53 PM
08/26/13 02:53 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Re: correct brake booster and master cylinder? [Re: gtx6970] #1490945
08/26/13 05:35 PM
08/26/13 05:35 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I corrected my above post.
Note: the nipple I and GTX6970 are showing aren't 100% correct, it should come straight out of booster not angle.
Re: correct brake booster and master cylinder? [Re: ] #1490946
08/27/13 09:54 AM
08/27/13 09:54 AM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Here you go.....this is an A12 - but same brake set-up you are after.
Re: correct brake booster and master cylinder? [Re: FJ5_Fish] #1490947
08/27/13 10:00 AM
08/27/13 10:00 AM
Ok, thanks everyone. Bill, (or anyone else) would the master cyl be painted black like that? I have seen a majority of them natural and not painted.
Re: correct brake booster and master cylinder? [Re: ] #1490948
08/27/13 10:27 AM
08/27/13 10:27 AM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Natural on original cars.
Re: correct brake booster and master cylinder? [Re: FJ5_Fish] #1490949
08/27/13 04:26 PM
08/27/13 04:26 PM
thanks. thats what I thought! I know the disc brake m/c's got painted with the unit. Just seemed strange that the lid on the one pictured above was gold while the core was black.
