block preferances. why 383 over 400?
#1490746
08/25/13 09:40 PM
08/25/13 09:40 PM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
I was told by guy today on the phone that a built 383 will outrun a 400 any day of the week. Now, this guy was calling about 71 newport that Im selling, I listed it for $1000 and stated that I would be keeping my 400 engine (cause its a 230 cold weather block.) He wants the whole car, and Im guessing he is telling me how much better a 383 can be built than a 400 because he wants my 400. My first thought to his statement was, uh you can make a 340 outrun a 400 if you have enough money.. its all in what you do to it.
So, is there some key feature to a 383 that makes them better blocks for high horsepower and stroker combinations? and not for unlimited budget builds, lets say the the budget is $8,000 and you wanted a reliable 650hp street/strip car
Re: block preferances. why 383 over 400?
[Re: Adam71Charger]
#1490750
08/26/13 12:13 AM
08/26/13 12:13 AM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
Bump the price up $1000 then I will drop off a complete one at your house next month for $750 when I go to Seattle.
You make more money and do less work He gets his silly numbers matching 400 2bbl And I sell a spare engine sitting around.
[Re: HotRodDave]
#1490751
08/26/13 12:19 AM
08/26/13 12:19 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
400s are bow wows till you stroke 1.. "Im not talking about petting it.."
I am truckless..
[Re: 340SHORTY]
#1490753
08/26/13 12:43 AM
08/26/13 12:43 AM
Posts: 3,445 N.Wilkesboro,NC
DusterKrazy
N.Wilkesboro,NC
Don't agree at all. All a 400 needs is compression. It has a cylinder bore even larger than the 440. Loves to rev just like the 383. My slightly modified one in my '65 Chrysler moves it very well.
[Re: chromedome426]
#1490756
08/26/13 11:04 AM
08/26/13 11:04 AM
Of all the "conventional wisdom" about engines , the Big Bore - Short stroke deal is the truth. It Works! The bigger bore is always, always better. Two of the baddest big block Mopars I have ever seen were 4.500 bore and very short stroke. They made massive power. I likey 400's any day!
[Re: Adam71Charger]
#1490759
08/26/13 06:01 PM
08/26/13 06:01 PM
RapidRobert
Slightly OT but a 400 with a 440 crank is a good plan. I see 440 steel cranks on occaision for $100-125 & this combo (451) or offset grinding the 440 crank (470) yields plenty of cubes & the B block is a better fit in an A body & look what Andy got out of his 470-550 horsepower! Yes he had killer (alum) heads which you're way ahead to go with them anyhow rather than antiquated iron heads but it is simple & easily doable. The biggest expense (besides the heads) is the pistons but you're gonna need them whichever way you go.
