Front Bumper Brackets, 72-93 trucks
#1490233
08/25/13 10:36 AM
08/25/13 10:36 AM
Posts: 6,019 Morningside
AdventurerSport
waaaay out there in left field
Morningside
I have a '76 W100 and I also have a brand new bumper from Mopar sitting in my shop, but the two will not go together! Here's the jist: Many years ago, my Dad bought a new front bumper for (then-his) 1976 W100 and never got around to putting it on. Well, I want to put it on this truck now (mine now), and the holes in the bumper are spaced differently than the original, so the brackets that I have do not work. Here is my question: When our dealer ordered this bumper, was it for a later model (81-93?) maybe? The original bumper has bolts spaced approx. 33" wide and 5.5" apart (top to bottom). The new bumper has the same 33", but top to bottom the bolts are only 4" apart. Would brackets off of a newer model, that fit the 4" bumper bolt pattern, still bolt to the frame of my '76? Has a three bolt triangular pattern on the frame for the bumper brackets. Anyone done this before? Please advise. Thank you! JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red 06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II 06 Chrysler 300C AWD 5.7L Hemi 10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI 10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI 11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red 16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
Re: Front Bumper Brackets, 72-93 trucks
[Re: AdventurerSport]
#1490235
08/25/13 11:28 AM
08/25/13 11:28 AM
Posts: 1,357 central Florida
VL21
central Florida
I am going the other way ...earlier bumper on my '85.
I just went and measured the '79-80 bumper I bought (used, with brackets) and the bolt holes are a little under 5" apart?
Bumper guards cover the mounting holes.
The 81 up bumpers are noticeably different, have a character line about 3" or so down from the top, and I think they are slightly wider, maybe wrap around the fender a little.
Got a picture or a part #?
Is it possible that the bumper is for a van?
The frame ends are all the same as far as I know, 3 bolt triangular, and the brackets will swap.
I haven't installed the earlier one yet, I think I can straighten my '85 one with a little help, and would like to do it before swapping the earlier one I want on there.
It takes gasoline to interest me.
[Re: buildanother]
#1490237
08/25/13 02:22 PM
08/25/13 02:22 PM
AdventurerSport
Morningside
New bumpe has the character line that the old one does not. Otherwise, dimensionally the same (or close enough), just the spacing of bolt holes on the bumper is different. I wonder if its 82-85 or so? Looks like the bumper in the picture above on the tan truck, albeit without bumper guards. Thanks
JS
#1490238
08/25/13 04:25 PM
08/25/13 04:25 PM
AdventurerSport
Morningside
so, I'm likely looking for an 82-85 or 86-up bumper bracket set. Thanks for the info, I'll check the local Grab and Go (self-service auto salvage) this week. Thanks again
JS
#1490239
08/25/13 08:03 PM
08/25/13 08:03 PM
Posts: 7,833 east side of Ohio
basketcase
east side of Ohio
I removed a front bumper(at the frame) froma a '77, and bolted it directly to my '87 and '88, using the brackets from the '77. same same.
1981 Dodge D150 360 auto
[Re: basketcase]
#1490240
08/25/13 08:10 PM
08/25/13 08:10 PM
basketcase
east side of Ohio
I should still have the front bumper off my '85, ans IIRC it has the brackets. PM me it you need them. It sounds like that's the style of yours.
[Re: 340SHORTY]
#1490242
08/26/13 06:14 PM
08/26/13 06:14 PM
basketcase
east side of Ohio
and that was the reason for my next post saying I had brackets for an '85 style bumper.....
