71' Cuda D/S rear inner wheel well bracket locations #1490028
08/24/13 11:34 PM
08/24/13 11:34 PM
Fremont, CA.
Topcat Offline OP
Topcat  Offline OP
Fremont, CA.
I'm wrapping up the interior on my car.
There are 2 brackets I have that I can't recall where their exact location was. I know they're somewhere at the lowest point of the inner wheelwell on the driver's side. Just behind but inside the door opening.
This one is what I'm really wanting to know where it goes. It has a plastic dip over it. There's another that is smaller.
Any pictures of these how they go would be appreciated.
Re: 71' Cuda D/S rear inner wheel well bracket locations [Re: Topcat] #1490029
08/25/13 12:12 AM
08/25/13 12:12 AM
South, FL
cudaized Offline
cudaized  Offline
South, FL
That one should attach just in front of the gusset bracket under the window crank, just above the floor.
Hard to see in this picture.
Re: 71' Cuda D/S rear inner wheel well bracket locations [Re: cudaized] #1490030
08/25/13 12:25 AM
08/25/13 12:25 AM
Fremont, CA.
Topcat Offline OP
Topcat  Offline OP
Fremont, CA.
The picture you have I believe is the side mount bracket for the rear seat if I'm correct?
I have that mounted already just as yours is in the picture.
