Yikes! Look at This Broken Wheel Stud #1489855
08/24/13 01:28 PM
08/24/13 01:28 PM
SW Ohio
cgall Offline OP
cgall  Offline OP
SW Ohio
Pulled front wheels to mount new frontrunners for this weekend, one stud was broken and the others are rusted! These are 5 years old.
Re: Yikes! Look at This Broken Wheel Stud [Re: cgall] #1489856
08/24/13 01:30 PM
08/24/13 01:30 PM
SW Ohio
cgall Offline OP
cgall  Offline OP
SW Ohio
The lugs are still chrome in the threads, they will clean up.
Re: Yikes! Look at This Broken Wheel Stud [Re: cgall] #1489857
08/24/13 01:31 PM
08/24/13 01:31 PM
Q
Quicktree Offline
Quicktree  Offline
Q
over torque?
Re: Yikes! Look at This Broken Wheel Stud [Re: cgall] #1489858
08/24/13 01:32 PM
08/24/13 01:32 PM
SW Ohio
cgall Offline OP
cgall  Offline OP
SW Ohio
Broken stud looks like it rusted thru. Ordered 10 ARP screw-in studs yesterday, but car is parked this weekend.
Re: Yikes! Look at This Broken Wheel Stud [Re: cgall] #1489859
08/24/13 01:51 PM
08/24/13 01:51 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Hmmm...The good ole rust belt. Anti Seize is your friend. What were those torqued to? Cannot imagine it rusted through, more likely a crack was formed then rust took over. Did that break right at the flange? How tight are those studs in the hub??
Re: Yikes! Look at This Broken Wheel Stud [Re: cgall] #1489860
08/24/13 01:52 PM
08/24/13 01:52 PM
Q
Quicktree Offline
Quicktree  Offline
Q
that looks like the work of an impact gun
Re: Yikes! Look at This Broken Wheel Stud [Re: Quicktree] #1489861
08/24/13 02:08 PM
08/24/13 02:08 PM
SW Ohio
cgall Offline OP
cgall  Offline OP
SW Ohio
I use impact to remove, but hand tighten and torque to 90 ft. lbs. The broken one came out without effort and the other 9 lugs came off with normal resistance. the other side is rusted just as bad.
I replaced my rear studs in 1997 and they still look brand new.
Re: Yikes! Look at This Broken Wheel Stud [Re: cgall] #1489862
08/24/13 02:12 PM
08/24/13 02:12 PM
SW Ohio
cgall Offline OP
cgall  Offline OP
SW Ohio
Al, the stud broke at the end of the shank of the lug, about 1/4" from the face of the hub. The jam nut is locktighted on, the hub is aluminum. Studs were still tight in hub.
Re: Yikes! Look at This Broken Wheel Stud [Re: cgall] #1489863
08/24/13 03:08 PM
08/24/13 03:08 PM
okla.
sam64 Offline
sam64  Offline
okla.
aluminum and steel don't like each other,be sure and put never seize on new studs to keep rust away.i just put new wheel studs on my faster car just for peace of mind,12 years of high ten second passes probably didn't hurt them.
Re: Yikes! Look at This Broken Wheel Stud [Re: sam64] #1489864
08/24/13 03:17 PM
08/24/13 03:17 PM
Roseville MN
72swgnr Offline
72swgnr  Offline
Roseville MN
you must use stainless fastening devices when working with aluminum (or aluminum) as stated regular steel and aluminum dont mix. corrosion starts to happen almost immediately.
Re: Yikes! Look at This Broken Wheel Stud [Re: cgall] #1489865
08/24/13 05:28 PM
08/24/13 05:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Move to Cally and you won`t have those problems..........
Re: Yikes! Look at This Broken Wheel Stud [Re: Thumperdart] #1489866
08/24/13 06:38 PM
08/24/13 06:38 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Wow! my 01 pickup doesn't have that much rust on the hubs!! ....what thump said!!
corrosion at the point of disimilar metals...
Re: Yikes! Look at This Broken Wheel Stud [Re: J_BODY] #1489867
08/24/13 06:43 PM
08/24/13 06:43 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I always put just a little oil on my studs anytime my wheels are off.
Re: Yikes! Look at This Broken Wheel Stud [Re: 72swgnr] #1489868
08/24/13 06:52 PM
08/24/13 06:52 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
That is a common very wrong misconception. Actually SS and alum have a greater corrosion potential, mainly of the alum.
To Op, a single sheared stud like pictured is likely only caused by being defective or previously partly over tighten, and time/fatigue/corrosion finished the task, or operated when tight and all the others are loose.
Re: Yikes! Look at This Broken Wheel Stud [Re: jcc] #1489869
08/24/13 07:05 PM
08/24/13 07:05 PM
SW Ohio
cgall Offline OP
cgall  Offline OP
SW Ohio
I think this is from bad steel! I have driven old Mopars thru some of the hardest winters in Ohio and have never seen anything like this. Studs should be heat treated and the black oxide should prevent surface rust for a lifetime, even when installed in an aluminum hub.
Re: Yikes! Look at This Broken Wheel Stud [Re: cgall] #1489870
08/24/13 07:22 PM
08/24/13 07:22 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
lucky you found this before anything major happened. unlike a racer at our track who had this mishap. unbelievable photography.
Re: Yikes! Look at This Broken Wheel Stud [Re: rebel] #1489871
08/24/13 10:27 PM
08/24/13 10:27 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Great, now we need lug nut tethers.
Re: Yikes! Look at This Broken Wheel Stud [Re: jcc] #1489872
08/24/13 11:51 PM
08/24/13 11:51 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I can't believe you beat me to that....
Re: Yikes! Look at This Broken Wheel Stud [Re: cgall] #1489873
08/25/13 12:23 AM
08/25/13 12:23 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I had a set of those break in 10 street miles. The company that sold the axles quickly replaced them claiming poor heat treat. The replacements never were a problem but my thinking is the design is poor at best. All axles I order I ask for a press in stud. My studs were not rusty like yours and I always use lube on the threads but have been told not to do so. I'd guess(only that) your lug nut seized on install and when you hit it to remove it the stud broke.
Re: Yikes! Look at This Broken Wheel Stud [Re: cgall] #1489874
08/25/13 03:22 PM
08/25/13 03:22 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Yup, replace them all
I've heard stories of rusted nuts on this site before, but never believed it till now.
Yeah, it's got a smallblock.
