Re: Test Fit New Tires 285/40/18
[Re: 1fastabody]
#1489427
08/23/13 02:24 PM
08/23/13 02:24 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Nice, proof will be when you get out there and run thru some tight turns at speed. Short sidewalls should help keep tire deflection under control.
[Re: Supercuda]
#1489428
08/23/13 02:53 PM
08/23/13 02:53 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Nice pics, cool car and great intentions! Can you tell us the rim specs... brand, width, back spacing... and weight of the rims if that's known, too?
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Supercuda]
#1489429
08/23/13 02:59 PM
08/23/13 02:59 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Don't do any trimming on the front until it gets completed and aligned with some negative camber etc. You'll be surprised what you get away with. Looks great with all that meat. I assume those are 18x10's with around 6.5" bs?
Mopar to the bone!!!
[Re: Mopar Mitch]
#1489431
08/23/13 03:26 PM
08/23/13 03:26 PM
Posts: 153 Wildwood, FL
1fastabody
Wildwood, FL
Wheels are OE Wheels FR500 Mustang Replicas. They are 18x10 with 6.37 back spacing. The center hub is just a little small so I have a .250 spacer on front and rear. Once I get the car to the ride height that I want I will play with spacing more. This isn't the exact wheel that I wanted for the car but being on a budget and at only $135 each shipped, you can't beat it. I'm building this as my family cruzier, but want to be able to play to.
[Re: 1fastabody]
#1489432
08/23/13 03:32 PM
08/23/13 03:32 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Will you be at Gartlis with the car? Be nice to check it out.
[Re: 1fastabody]
#1489434
08/23/13 04:11 PM
08/23/13 04:11 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Can you turn the wheels lock to lock without contact?
My 65 Belvedere has a 245/45-18 up front. It rubs the front of the rail, the rear of the rail, and will barely brush the outside of the fender when turning into a driveway.
I'm not sure if the inside rubbing is due to the K frame and steering swap or if the car is simply maxed out.
There's not much difference between your car and mine.
[Re: feets]
#1489435
08/23/13 05:09 PM
08/23/13 05:09 PM
1fastabody
Wildwood, FL
It looks like it may rub around full lock. I haven't got the suspension and ride height where I want it so I have just looked at this a little. I have some room to play with spacing if needed.
[Re: feets]
#1489436
08/23/13 08:46 PM
08/23/13 08:46 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
Those FR 500's look great! One of these days I want to try my 19" GT 500 wheels on one of my old cars to see who they look.
A new iron curtain drawn across the 49th parallel
[Re: jcc]
#1489439
08/24/13 04:41 AM
08/24/13 04:41 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
I vote we change the name of this forum to: "Big Fronts Only"
[Re: autoxcuda]
#1489440
08/24/13 11:35 AM
08/24/13 11:35 AM
72Swinger
Nebraska
Wonder if height plays as much or more of a roll in frame rail rub? 245/45/18 dia=26.68 width=9.65 285/40/18 dia=26.98 width=11.22 285/35/18 dia=25.85 width=11.22
[Re: 72Swinger]
#1489441
08/24/13 11:49 AM
08/24/13 11:49 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I haven't played around enough yet with my Cuda, as I'm stalled out in the body work stage, but on my Dakota, I can say that the lower you go, the smaller tire you have room for.
or in other words, as you lower the vehicle more, there is less and less room for big wide tires up front.
**Photobucket sucks**
[Re: 70Cuda383]
#1489442
08/24/13 04:58 PM
08/24/13 04:58 PM
72Swinger
Nebraska
I have 275/35/18s on the front of my Dart and I am maxed on heighth but im tempted to go with 18x9.5's and 285 or 295s just because. Any more height and im forced to raise it or mini tub the front lol.
