Test Fit New Tires 285/40/18 #1489424
08/23/13 02:06 PM
08/23/13 02:06 PM
Wildwood, FL
1fastabody Offline OP
Wildwood, FL
Well I decided on what tires to use. I went with the Continental Extreme Contact DW. I'm going to try and run a 285/40/18 square setup. I test fit them on the front and rear yesterday and they seem like they fit nice. I still have to lower the car and do all my suspension upgrades but just trying to get my tire fitment nailed down. Here are a few pics of it.
Re: Test Fit New Tires 285/40/18 [Re: 1fastabody] #1489425
08/23/13 02:08 PM
08/23/13 02:08 PM
Wildwood, FL
Wildwood, FL
Another shot
Re: Test Fit New Tires 285/40/18 [Re: 1fastabody] #1489426
08/23/13 02:11 PM
08/23/13 02:11 PM
Wildwood, FL
Wildwood, FL
Pic 3
Re: Test Fit New Tires 285/40/18 [Re: 1fastabody] #1489427
08/23/13 02:24 PM
08/23/13 02:24 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Nice, proof will be when you get out there and run thru some tight turns at speed. Short sidewalls should help keep tire deflection under control.
Don't be the exception.
Re: Test Fit New Tires 285/40/18 [Re: Supercuda] #1489428
08/23/13 02:53 PM
08/23/13 02:53 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Nice pics, cool car and great intentions! Can you tell us the rim specs... brand, width, back spacing... and weight of the rims if that's known, too?
Re: Test Fit New Tires 285/40/18 [Re: Supercuda] #1489429
08/23/13 02:59 PM
08/23/13 02:59 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Don't do any trimming on the front until it gets completed and aligned with some negative camber etc. You'll be surprised what you get away with. Looks great with all that meat. I assume those are 18x10's with around 6.5" bs?
Mopar to the bone!!!
Re: Test Fit New Tires 285/40/18 [Re: 1fastabody] #1489430
08/23/13 03:07 PM
08/23/13 03:07 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Yes they do
I vote we change the name of this forum to: "Big Fronts Only"
Re: Test Fit New Tires 285/40/18 [Re: Mopar Mitch] #1489431
08/23/13 03:26 PM
08/23/13 03:26 PM
Wildwood, FL
Wildwood, FL
Wheels are OE Wheels FR500 Mustang Replicas. They are 18x10 with 6.37 back spacing. The center hub is just a little small so I have a .250 spacer on front and rear. Once I get the car to the ride height that I want I will play with spacing more. This isn't the exact wheel that I wanted for the car but being on a budget and at only $135 each shipped, you can't beat it. I'm building this as my family cruzier, but want to be able to play to.
Re: Test Fit New Tires 285/40/18 [Re: 1fastabody] #1489432
08/23/13 03:32 PM
08/23/13 03:32 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Will you be at Gartlis with the car?
Be nice to check it out.
Re: Test Fit New Tires 285/40/18 [Re: jcc] #1489433
08/23/13 03:37 PM
08/23/13 03:37 PM
Wildwood, FL
Wildwood, FL
I will be there just not sure the car will be. I have the back glass coming out so I can fix a few pin holes around rubber. I'm not sure if I will have that fixed in time. I only live about 10-15 minutes from there.
Re: Test Fit New Tires 285/40/18 [Re: 1fastabody] #1489434
08/23/13 04:11 PM
08/23/13 04:11 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Can you turn the wheels lock to lock without contact?
My 65 Belvedere has a 245/45-18 up front. It rubs the front of the rail, the rear of the rail, and will barely brush the outside of the fender when turning into a driveway.
I'm not sure if the inside rubbing is due to the K frame and steering swap or if the car is simply maxed out.
There's not much difference between your car and mine.
- Stu Harmon
Re: Test Fit New Tires 285/40/18 [Re: feets] #1489435
08/23/13 05:09 PM
08/23/13 05:09 PM
Wildwood, FL
Wildwood, FL
It looks like it may rub around full lock. I haven't got the suspension and ride height where I want it so I have just looked at this a little. I have some room to play with spacing if needed.
Re: Test Fit New Tires 285/40/18 [Re: feets] #1489436
08/23/13 08:46 PM
08/23/13 08:46 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
Those FR 500's look great! One of these days I want to try my 19" GT 500 wheels on one of my old cars to see who they look.
A new iron curtain drawn across the 49th parallel
Re: Test Fit New Tires 285/40/18 [Re: 1fastabody] #1489437
08/23/13 10:53 PM
08/23/13 10:53 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Regarding the window, Its not going to rain, and with those tires you should be able to out run the rain.
Re: Test Fit New Tires 285/40/18 [Re: jcc] #1489438
08/23/13 11:34 PM
08/23/13 11:34 PM
Battle Ground, Washington
Rapom65 Offline
Rapom65  Offline
Good looking wheels and affordable too, whats not to like about that?
Very nice car.
Re: Test Fit New Tires 285/40/18 [Re: jcc] #1489439
08/24/13 04:41 AM
08/24/13 04:41 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Re: Test Fit New Tires 285/40/18 [Re: autoxcuda] #1489440
08/24/13 11:35 AM
08/24/13 11:35 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Wonder if height plays as much or more of a roll in frame rail rub?
245/45/18
dia=26.68
width=9.65
285/40/18
dia=26.98
width=11.22
285/35/18
dia=25.85
width=11.22
Re: Test Fit New Tires 285/40/18 [Re: 72Swinger] #1489441
08/24/13 11:49 AM
08/24/13 11:49 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I haven't played around enough yet with my Cuda, as I'm stalled out in the body work stage, but on my Dakota, I can say that the lower you go, the smaller tire you have room for.
or in other words, as you lower the vehicle more, there is less and less room for big wide tires up front.
**Photobucket sucks**
Re: Test Fit New Tires 285/40/18 [Re: 70Cuda383] #1489442
08/24/13 04:58 PM
08/24/13 04:58 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I have 275/35/18s on the front of my Dart and I am maxed on heighth but im tempted to go with 18x9.5's and 285 or 295s just because. Any more height and im forced to raise it or mini tub the front lol.
Re: Test Fit New Tires 285/40/18 [Re: 1fastabody] #1489443
08/24/13 10:51 PM
08/24/13 10:51 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Your car looks fantastic with those tires.
I can't believe you got them to fit. My 66 Coronet is maxed out with 255/45/18 and 18x8 with 5.5 backspace. It rubs on the right front rear subframe rail occasionally at full lock with some suspension compression.
