71 A-Body clutch switch mounting? #1489413
08/23/13 01:48 PM
08/23/13 01:48 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Does anyone have good pictures of how the clutch interlock switch mounts?
Bought an NOS one to replace the MIA one in my Demon but want to spend as little time as I have to upside down, not as young as I used to be!!!!
Re: 71 A-Body clutch switch mounting? [Re: RJS] #1489414
08/23/13 02:13 PM
08/23/13 02:13 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
I went through Brent's Ruster to Duster thread again but the picture he shows is the wrong side of the pedal assembly for what I need.
Ron
Re: 71 A-Body clutch switch mounting? [Re: RJS] #1489415
08/23/13 09:22 PM
08/23/13 09:22 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Night crowd?
Re: 71 A-Body clutch switch mounting? [Re: RJS] #1489416
08/24/13 01:19 PM
08/24/13 01:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Not sure what body this is.
Re: 71 A-Body clutch switch mounting? [Re: RJS] #1489417
08/24/13 04:23 PM
08/24/13 04:23 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Call Brewer's Performance..
937.947.4416 or 937.698.4259
Talk to Wayne or Dan, they can help you..
Just my $0.02...
Re: 71 A-Body clutch switch mounting? [Re: Sinitro] #1489418
08/24/13 04:50 PM
08/24/13 04:50 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Your photo is of an E-body set-up John
Re: 71 A-Body clutch switch mounting? [Re: mccannix] #1489419
08/24/13 06:25 PM
08/24/13 06:25 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Yep that photo looked like my old 72 B-Body.
Still hoping someone A-Body schooled has a picture to show.
Here's the switch I bought...
Ron
Re: 71 A-Body clutch switch mounting? [Re: RJS] #1489420
08/25/13 12:21 PM
08/25/13 12:21 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
I won't keep beating this dead horse but can anyone poke a camera under their dash for me?
Thanks Ron
Re: 71 A-Body clutch switch mounting? [Re: RJS] #1489421
08/26/13 11:20 AM
08/26/13 11:20 AM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
OK beating dead horse!!!
Re: 71 A-Body clutch switch mounting? [Re: RJS] #1489422
08/26/13 12:15 PM
08/26/13 12:15 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
This is an A-body pedal assymbly. Not sure what exact year. I believe the pedal pad is an indication if it's an early or later setup (assuming the pad is original). Looks like you have the same clutch switch as in my pictures below.
Just went in the garage and shot these pictures...
Does this help?
Re: 71 A-Body clutch switch mounting? [Re: autoxcuda] #1489423
08/26/13 07:42 PM
08/26/13 07:42 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Does this help?
Wow a picture is worth a thousand words!!!!
If my pedal assembly was out and in my hands I may have figured it out, but since it's not...
Your pictures spelled out what I needed to see, Thank You very much!
Ok so now it's bolted in but I think the hard swinging rod that catches the switch may be broken in my car.
Can you tell me how long that little piece of wire is supposed to be?
The information that can be found on Moparts is incredible!!!!
Thanks Ron
