Re: 71 A-Body clutch switch mounting?
[Re: RJS]
#1489415
08/23/13 09:22 PM
08/23/13 09:22 PM
Posts: 6,224 JERSEY
RJS
JERSEY
[Re: RJS]
#1489417
08/24/13 04:23 PM
08/24/13 04:23 PM
Posts: 5,447 So Cal
Sinitro
So Cal
Call Brewer's Performance.. 937.947.4416 or 937.698.4259 Talk to Wayne or Dan, they can help you.. Just my $0.02...
[Re: mccannix]
#1489419
08/24/13 06:25 PM
08/24/13 06:25 PM
Posts: 6,224 JERSEY
RJS
JERSEY
Yep that photo looked like my old 72 B-Body. Still hoping someone A-Body schooled has a picture to show. Here's the switch I bought... Ron
[Re: RJS]
#1489421
08/26/13 11:20 AM
08/26/13 11:20 AM
Posts: 6,224 JERSEY
RJS
JERSEY
[Re: RJS]
#1489422
08/26/13 12:15 PM
08/26/13 12:15 PM
Posts: 27,480 So Cal
autoxcuda
So Cal
This is an A-body pedal assymbly. Not sure what exact year. I believe the pedal pad is an indication if it's an early or later setup (assuming the pad is original). Looks like you have the same clutch switch as in my pictures below. Just went in the garage and shot these pictures... Does this help?
[Re: autoxcuda]
#1489423
08/26/13 07:42 PM
08/26/13 07:42 PM
Posts: 6,224 JERSEY
RJS
JERSEY
Does this help?
Wow a picture is worth a thousand words!!!! If my pedal assembly was out and in my hands I may have figured it out, but since it's not... Your pictures spelled out what I needed to see, Thank You very much!
Ok so now it's bolted in but I think the hard swinging rod that catches the switch may be broken in my car. Can you tell me how long that little piece of wire is supposed to be?
The information that can be found on Moparts is incredible!!!! Thanks Ron
