What's the best HD bedliner coating in a spray can? #1489345
08/23/13 09:55 AM
08/23/13 09:55 AM
fullmetaljacket Offline OP
I want to spray on a heavy duty Bedliner of the color black in the interior floor of my car instead of a carpet.
Which spray on Bedliner that comes in a spray can will work the best with the proper prep and will look the best in the long term?
If not, then which one as a roll on?
Real world experiences only, no guesstimates please.
Re: What's the best HD bedliner coating in a spray can? [Re: fullmetaljacket] #1489346
08/23/13 04:54 PM
08/23/13 04:54 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
I've done 5 beds. The first one I tried using 2 different brands of spray on. It was a colossal failure both times. The tips plug up and the spray isnt uniform.
I have used Walmart and Advance auto's brands of roll on.The Rustoleum brand works great.The only problem is the mixer that goes on the drill is cheap and will break. I just migged a lil paddle on the rod to fix that.
Stuff looks great when done.Just make sure you do good prep work.
The oldest one was done about 5 years ago and looks great.
Re: What's the best HD bedliner coating in a spray can? [Re: fullmetaljacket] #1489347
08/23/13 05:53 PM
08/23/13 05:53 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I did the floor of my '65 with the Duplicolor stuff that comes in quart cans at Autozone. Worked pretty darn well.
This is the land of the free because of the brave
Re: What's the best HD bedliner coating in a spray can? [Re: rbstroker] #1489348
09/06/13 09:31 AM
09/06/13 09:31 AM
Central TX
roe Offline
roe  Offline
Central TX
Edit: found a pic, its the only one I had left. Hood, roof, and bed rails, even held up to the sun.
I did an '89 F250 long bed, bed rails, roof and hood to replace faded and cracking paint. Looked great, held up great, and was easy to roll on. I did about 4 coats after sanding all the crappy paint off. I sold that truck though, so no pics.
I also helped a buddy do his GMC truck bed and bed rails. Turned out great and held to his dirt bike and military gear, etc...being in the back.
I think it would work great for your floor. Just roll it on in a well ventilated area as the fumes are strong. I did mine in the driveway because the fumes were too much in the garage.
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: What's the best HD bedliner coating in a spray can? [Re: roe] #1489349
09/06/13 04:40 PM
09/06/13 04:40 PM
KS
MoparKansas Offline
MoparKansas  Offline
KS
I would not use the roll on. My son did the bottom half of his Jeep with it one time and it looked like crap. The second time he decided to do the whole jeep and we got the big drywall sprayer that you hook to a compressor from Harbor Freight for about $20 - it has a big material holding bin on top. It sprays the stuff all over (so make sure you tape off everything very well that you don't want covered), but gave a very nice consistent finish using the Duplicolor in from a gallon container. Plan on throwing the gun away when you are done. I tried to clean it for about 20 minutes and quit.
Re: What's the best HD bedliner coating in a spray can? [Re: fullmetaljacket] #1489350
09/06/13 07:07 PM
09/06/13 07:07 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Don't do it, you wanna make your car heavier?
Re: What's the best HD bedliner coating in a spray can? [Re: RV2] #1489351
09/06/13 09:42 PM
09/06/13 09:42 PM
IN
ahy Offline
ahy  Offline
IN
Is spray on with compressed air OK? I used the SEM kit with supplied cheap gun on a PU bed. It came out very well. I got the material from Auto Body Depot ordered on line. If you Google "autocolorlibrary.com" that will get you there. Prep is same as paint. Clean, treat any rust and prime first. The primer needs to handle the hotter solvents in auto type paint.
The SEM stuff is catalyzed so it sets up faster and harder than the single stage products.
Re: What's the best HD bedliner coating in a spray can? [Re: ahy] #1489352
09/07/13 07:49 AM
09/07/13 07:49 AM
scratchnfotraction Offline
sprayed inside cab and underside/firewall on my 90 replacment cab
used the rustoleum spray in bedliner with the bedliner spray gun.
good stuff and nice finish. yes you would need to tape it off stuff you dont want coverd.
I did the bed of my 88-440 truck with the hurculiner roll on = grity crap that has faded already in 2.5 yrs, grit will brush off by hand and leave a black chalk like crap on your hands. it will get redone with the rustoleum next.
Re: What's the best HD bedliner coating in a spray can? [Re: scratchnfotraction] #1489353
09/07/13 07:50 AM
09/07/13 07:50 AM
