Challenger door panels........
#1489246
08/22/13 11:11 PM
08/22/13 11:11 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey gang... Got my buddy's car back to finish the assembly of his '71 v-code Challenger R/T........
Ok for you E-body gurus...... This clip is apparently something that helps secure the middle of the door panel to the inner door sheetmetal so there's not a wide separation..... Does anyone reproduce this clip and was it ONLY used in the middle position of the panel? It may be backwards, I just placed it on the panel to take the picture. Also, the injected panels, has anyone installed them and if so, how much tweaking did you have to do? The panel doesn't fit perfectly on the top forward edge....
Thanks in advance... Troy
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: Challenger door panels........
[Re: hemi68charger]
#1489250
08/23/13 10:29 AM
08/23/13 10:29 AM
Posts: 1,822 Colorado
denfireguy
Colorado
Thanks for the post...I found one of those in the passenger side door laying on the bottom rusted and never knew what it was for. The driver's door was totally missing. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: hemi68charger]
#1489251
08/23/13 10:34 AM
08/23/13 10:34 AM
denfireguy
Colorado
On the Cuda, I used Metro's piece. It did not fit perfectly but in a hot garage with the panel warm, I could get it to kind of stretch over everything it needed to go over. Just a little patience and it went on just right. Craig
