Short Shift Kit for 03-05 NV5600 6spd? #1489126
08/22/13 07:28 PM
08/22/13 07:28 PM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
Anyone use this product and if so what is your opinion of it? I just sold my 98.5 Cummins Auto for a very clean 03 5.9 6spd but the shifter leaves a little to be desired. Wondering if this will help with the funky shifter and make the gates a bit more pronounced? Reviews or opinions would be welcomed. Here is the product below.
http://www.genosgarage.com/BD-SHORT-SHIFT-KIT-03-05-NV5600/productinfo/BD-1031055/
Re: Short Shift Kit for 03-05 NV5600 6spd? [Re: SCATPK] #1489127
08/23/13 09:32 AM
08/23/13 09:32 AM
Kansas
cascius Offline
cascius  Offline
Kansas
A guy I used to work with had one, and personally I didn't think it was that great. It does nothing to make the gates feel any different, and it makes it harder to hit the right gear since it takes less movement to move the shift rail the same distance. Maybe it's something you'd get used to, but having a stock 6 speed truck at the time and then driving that one just didn't feel right.
Re: Short Shift Kit for 03-05 NV5600 6spd? [Re: cascius] #1489128
08/23/13 12:09 PM
08/23/13 12:09 PM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
Thanks for the info. I have a buddy with a 04 6spd and he wants to get one, I will try his out when he changes out the original stick.
Re: Short Shift Kit for 03-05 NV5600 6spd? [Re: SCATPK] #1489129
08/23/13 01:18 PM
08/23/13 01:18 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
A friend of mine has a setup that allows him to use the shifter from an SRT-10 Ram. It shortened the throw up some and feels pretty nice.
68 Barracuda Formula S 340
Re: Short Shift Kit for 03-05 NV5600 6spd? [Re: SCATPK] #1489130
08/27/13 04:45 PM
08/27/13 04:45 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I used the BD kit in my '02. It does make the shift throw shorter, it gives less mechanical advantage and therefore takes more effort to move the lever. I used the add-on cup holder (to the console) and the raised shift knob cleared better. A word of warning, be very carefull with the factory sleeves that go around the shift tower bolts. They look like .22 long rifle brass. I dropped one of them, I could never find it even after draining the transmission and removing both PTO plates. I decided, since it was brass, it would be ground up in the gears without damage to anything. I refilled the trans with Red Line syntheic, drove it 20,000 miles and never gave it another thought. The shift tower never loosened as I thought it might either. Would I spend the money to do it again? Probably not, you are never going to speed-shift a NV5600 and I have better uses for $200.00
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
