Brake distribution block question? #1489037
08/22/13 05:11 PM
08/22/13 05:11 PM
moparAL Offline OP
moparAL  Offline OP
I have a 73 Dodge Challenger and I am installing 4 wheel disc brakes. I just want to make sure before I buy these. I think I need a drum distribution block, not a proportioning valve. Does anyone have a part number or brand. A dealer says they have the correct part, I just want to be absolutely sure. Thanks everybody.
Re: Brake distribution block question? [Re: moparAL] #1489038
08/22/13 05:34 PM
08/22/13 05:34 PM
I am assuming you want a 4 wheel drum splitter with the electrical switch for the brake warning light? EDIT If so I'd think a 67 up 4 wheel drum splitter would be what you need (I'm thinking they added the warning light the same model year as the dual bowl which was 67)
Re: Brake distribution block question? [Re: RapidRobert] #1489039
08/22/13 10:00 PM
08/22/13 10:00 PM
BDW Online content
BDW  Online Content
check this out, probably what you need
http://www.summitracing.com/parts/wil-260-11179/overview/
Re: Brake distribution block question? [Re: moparAL] #1489040
08/23/13 04:22 AM
08/23/13 04:22 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Al, just go down to any good auto supply shop and get two of these. Get a 3/16 plug for the one to the rear brakes. Having two separate circuits (front/rear) makes it easier to plumb and tighten the brake line fittings. I've built many brake systems and trying to get a 3/16 brake line wrench to tighten a 5 port dist block is not fun. While you're there get a few extra plugs in case you want to test the master cylinder.
