Re: Best scattershield, lakewood, quicktime,? 67 Hem b-body
[Re: 408cuda]
#1488845
08/24/13 04:27 PM
08/24/13 04:27 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Your flywheel size will dictate your choice between Quicktime or Lakewood. Quicktime will only accommodate a 130 tooth wheel. It's a shame really because all my clutches and flywheels wont fit in a smaller lighter can Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: JohnRR]
#1488848
08/25/13 02:32 AM
08/25/13 02:32 AM
Posts: 610 White Creek, NY
408cuda
White Creek, NY
Sorry put this in the q&a section since it dropped out of sight so quick here.
Car will have manifolds. Have a 11" clutch/flywheel in stock as well as a 130 tooth flywheel but can go either way. Really just want the best fitting unit that is safe for say a 650 hp Hemi.
Quicktime is getting good reviews in the other section but nobody has used one in a bb b-body an OEM parts.
[Re: 408cuda]
#1488850
08/25/13 12:16 PM
08/25/13 12:16 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
Manifolds you have to run a 130 tooth wheel if you don't have the stock hemi stuff ... so I am told here on this site when I asked .. starter to manifold clearance issue , may not be able to run a mini starter ???
[Re: 408cuda]
#1488851
08/25/13 05:05 PM
08/25/13 05:05 PM
Posts: 1,532 off the grid
340B5
off the grid
Smart idea to have the shield. Don't forget to indicate it in when installing. I think it's .005 or .oo6 max runout on the trans opening IIRC. It should come w/ instructions for indicating in. FWIW when I installed my Lakewood, I had to cut off and re-weld the clutch bellcrank mount. That was 30 yrs ago, and hopefully that's changed. They're a pain sometimes, but so is being crippled.
Yeah, it's got a smallblock.
[Re: 408cuda]
#1488852
08/25/13 09:19 PM
08/25/13 09:19 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
Had no problem fitting the quicktime w/66 belvedere. But there are issues. 1. had to reposition and reform the pivot that come with it. Slotted the holes and bent it so the fork was further on to the throw out bearing. 2. The ball mount for the z-bar is kind oh hokey. I stiffened it up by running a metal support from the top left trans bolt to the ball mount 3. yep, have to use a 130 tooth flywheel, if racing with a sintered iron disk it will be 10 inches 4. if racing with a counter weighted pressure plate then there is very little clearance between the counterweights and the bell. Had to make a .030" spacer between the bell and block plate 5. Had no issues with headers Lakewood owns quicktime. Do they even offer the Lakewood bell any more?
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: JohnRR]
#1488854
08/25/13 11:41 PM
08/25/13 11:41 PM
408cuda
White Creek, NY
Thanks for the replies. Still not sure which way I want to go but the lakewood sounds as good as any for less $.
Summit shows BB lakewood bells in stock and ready ship tomorrow for $460
Stuff I own
Self promotion
Things someone else said I claim as my own
