Carb Experts. Need help on this setup #1488484
08/21/13 07:11 PM
08/21/13 07:11 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
I am helping yet another friend today with his 58 Plymouth "Christine" Replica. When I went to help him out the last time, his damper lost all the paint and there was no groove for a timing reference. I pointed out to him that he needed a kickdown linkage as the guy who put the engine together for him, neglected to install this vital component. We finally got the Bouchillon kit after a month back order...what a PITA to install it...I have done the one on my Charger and I was done in an hour...it took me 4 hours UNDER the car alone.
Anyways, The underside is installed, the top side is installed but it needs a modification still to have the right geometry. The problem here is, the pedal was "designed" by whom I have no idea...that you accelerate by pushing forward. Is this how they did it back in the 50s? He had a holley 800on there and it was puking fuel everywhere so I installed my old 750 which works. I installed the kickdown bracket on the carb from Bouchillon but I installed it to PULL the carb to accelerate....the pedal was on the floor...so I redirected it to the top of the 1481 bracket so it PUSHES the carb open but there is alot of resistance and I KNOW it isn't supposed to operate this way.
What can I do to help this guy out...He is the owner of this car club but no one wants to touch his car and I am pretty much the only one knowledgeable enough to tackle it. Two pics coming up
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Carb Experts. Need help on this setup [Re: Pyper70] #1488485
08/21/13 07:12 PM
08/21/13 07:12 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
next pic
Re: Carb Experts. Need help on this setup [Re: Pyper70] #1488486
08/21/13 07:28 PM
08/21/13 07:28 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Try some lighter return springs. Those things are monsters for the set up your're doing.
Re: Carb Experts. Need help on this setup [Re: stumpy] #1488487
08/21/13 07:32 PM
08/21/13 07:32 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
I disconnected them in one of my many attempts...its as if the pivot point in the bracket on the carburetor is providing all the resistance...The gas pedal sits half way up with this setup...
How was it back in the Late 50s...was it a push method or a pull method. I have really ony worked on cars with the throttle cable attached to the throttle bracket via the intake manifold....never a bell crank to the pedal
Re: Carb Experts. Need help on this setup [Re: Pyper70] #1488488
08/21/13 08:00 PM
08/21/13 08:00 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
those old mopars had a mechanical push system for the throttle.
Re: Carb Experts. Need help on this setup [Re: lewtot184] #1488489
08/21/13 08:38 PM
08/21/13 08:38 PM
St.Lazare Quebec Canada
mrmopartech Offline
mrmopartech  Offline
Options,see if the under the dash mounting can be reversed to make it a pull system,make a longer lever to allow more leverage for the push rod to work the carb linkage.Putting a spring on the throttle to remove some of the spring pressure all ready built into the carb spring,but not enough to cause the carb to hang open.mrmopartech
Re: Carb Experts. Need help on this setup [Re: mrmopartech] #1488490
08/21/13 09:19 PM
08/21/13 09:19 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
The pedal, from what I saw...goes through the floor board with a solid linkage...to a bellcrank....and the forward movement is all with shafts. I wish I could put a cable on this setup and be done with it...its so easy....I may have to pull rank, get a 69 B-Body pedal and hammer and run a cable to the carb...
Re: Carb Experts. Need help on this setup [Re: Pyper70] #1488491
08/21/13 09:22 PM
08/21/13 09:22 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Or just use lighter springs on the return.
Re: Carb Experts. Need help on this setup [Re: stumpy] #1488492
08/21/13 09:39 PM
08/21/13 09:39 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Id get 1 of these http://www.summitracing.com/parts/edl-1481
and find a normal/simple pedal/cable system from almost any Mopar...
I am truckless..
Re: Carb Experts. Need help on this setup [Re: 340SHORTY] #1488493
08/21/13 09:42 PM
08/21/13 09:42 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
that bracket is already on there....it's the intermediary between the Carb linkage and the Bouchillon linkage
