brake pedal height help #1488293
08/21/13 11:03 AM
08/21/13 11:03 AM
yellow70charger Offline OP
Help , I have a 70 charger 4 speed with power disc brakes the pedal seems low to me (see pic) as it will not engage the brake light switch it seems this rod is too short (see other pic) Is this rod to short? or is the clutch pedal to high?
Re: brake pedal height [Re: yellow70charger] #1488294
08/21/13 11:07 AM
08/21/13 11:07 AM
pic of rod
Re: brake pedal height [Re: yellow70charger] #1488295
08/21/13 11:12 AM
08/21/13 11:12 AM
angle pic of pedal
Re: brake pedal height help [Re: yellow70charger] #1488296
08/21/13 11:22 AM
08/21/13 11:22 AM
Yes that one is way too short.
Re: brake pedal height help [Re: RapidRobert] #1488297
08/21/13 11:36 AM
08/21/13 11:36 AM
do you know where i could get a correct one?
Re: brake pedal height help [Re: yellow70charger] #1488298
08/21/13 12:38 PM
08/21/13 12:38 PM
Oklahoma
V
VoodooCLD Offline
VoodooCLD  Offline
V
Oklahoma
I was under the impression this was because of the power brakes which puts the pedal at a much lower position than the clutch.
I have the same issue, and was just gonna leave it. If there is a good fix, then i'm interested as well.
Re: brake pedal height help [Re: VoodooCLD] #1488299
08/21/13 12:44 PM
08/21/13 12:44 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
I always thought that was normal pedal height for power brakes and the brake light switch is adjustable. Do you have the rear brakes adjusted to where they bearly contact the drums? That will bring the pedal up some.
Re: brake pedal height help [Re: yellow70charger] #1488300
08/21/13 02:34 PM
08/21/13 02:34 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Pedal height mismatch is common with power brake/stick shift combos, it's because the brake pedal ratio is lower with power brakes.
Re: brake pedal height help [Re: John_Kunkel] #1488301
08/21/13 05:27 PM
08/21/13 05:27 PM
adjustabe switch should do it then( to solve brake lights), and be happy with it or may two heim joints and adjust/trim thread to make it a adjustable height.
Re: brake pedal height help [Re: yellow70charger] #1488302
08/21/13 05:36 PM
08/21/13 05:36 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
As long as it doesn't bottom out on the floor, its ok. If you read the service manual it tells you that power brake pedals are further down than manual pedals.Thats so you can keep your heel on the floor and not throw every body threw the windshield.
Re: brake pedal height help [Re: 71birdJ68] #1488303
08/21/13 05:39 PM
08/21/13 05:39 PM
that makes sense thank you for the responses i guess i'll leave it and get the switch
Re: brake pedal height help [Re: yellow70charger] #1488304
08/21/13 05:41 PM
08/21/13 05:41 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Also there is measurement for the switch. Look in the book.
Re: brake pedal height help [Re: 71birdJ68] #1488305
08/21/13 06:10 PM
08/21/13 06:10 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Also the low brake pedal helps with a 4 speed on a hill when you have to tap dance the three pedals on take off!
Re: brake pedal height help [Re: yellow70charger] #1488306
08/21/13 09:02 PM
08/21/13 09:02 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Dr Diff has them. http://www.doctordiff.com/62-70-adjustable-master-cylinder-push-rod.html
Re: brake pedal height help [Re: Lefty] #1488307
08/21/13 09:18 PM
08/21/13 09:18 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That's for a manual brake setup I believe.
Don't be the exception.
Re: brake pedal height help [Re: Supercuda] #1488308
08/21/13 09:20 PM
08/21/13 09:20 PM
Grand Prairie,Texas
Grand Prairie,Texas
You could just try adjusting the switch that's already there.
Re: brake pedal height help [Re: 71birdJ68] #1488309
08/22/13 12:25 PM
08/22/13 12:25 PM
Oklahoma
V
VoodooCLD Offline
VoodooCLD  Offline
V
Oklahoma
Hahaha! This made my morning.
Re: brake pedal height help [Re: VoodooCLD] #1488310
08/22/13 04:08 PM
08/22/13 04:08 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
If you notice, power brake pedals are about even with the gas pedal. They did that for a reason. Manual brakes, you have to use your whole leg, so you need the extra leverage to get the job done. Power brakes, the booster is doing the work.
What amazes me is back in the day, everybody knew this.Now, its forgotten.
Re: brake pedal height help [Re: 71birdJ68] #1488311
08/22/13 06:17 PM
08/22/13 06:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I don't think the power pedal height is by design, as I stated earlier, it's just a consequence of the different pedal ratio for power/manual (as the pedal ratio decreases the pedal drops).
Re: brake pedal height help [Re: John_Kunkel] #1488312
08/22/13 06:20 PM
08/22/13 06:20 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Read the service manual.
