Re: Filter bypass in right-angle SB oil filter adapter?
[Re: dsp]
#1488067
08/21/13 02:26 AM
08/21/13 02:26 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Never seen a bypass valve in the 1s I have seen.
I am truckless..
[Re: dsp]
#1488068
08/21/13 02:30 AM
08/21/13 02:30 AM
Posts: 2,042 Leucadia, Ca.
vdriver
Leucadia, Ca.
..Is the purpose of this plug to simply seal the cross-drilling in the adapter..
Yes, it's just a plug. Nothing behind it.
[Re: scratchnfotraction]
#1488070
08/21/13 10:47 AM
08/21/13 10:47 AM
RapidRobert
I'd suggest hitting the tool with a hammer rather than a steady pull which works better for breaking them free & if it's an alum adapter you might heat the plug & melt some wax into the threads if it's REAL tight so as to not potentially crack the alum case
