Page 5 of 14 1 2 3 4 5 6 7 13 14
Re: '71 Demon Project Build [Re: demon440] #148764
04/07/09 02:45 AM
04/07/09 02:45 AM
Rockford,IL
71Polara383 Offline
71Polara383  Offline
Rockford,IL
Everytime i look At this it gets me amped to work on mine. Keep it Up!
Re: '71 Demon Project Build [Re: VITC_GTX] #148765
04/07/09 03:14 AM
04/07/09 03:14 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Hey one thing I have just reccognized recently. Demons and Dusters quarters have an area about the size of your hand just behind the doors (circled) that has a factory depression that may appear to be a dent (both sides of the car have them). Just so you don't drive yourself crazy filling & blocking it flat, it's SUPPOSED to be there.
Re: '71 Demon Project Build [Re: ScottSmith_Harms] #148766
04/07/09 03:21 AM
04/07/09 03:21 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
It really shows in this particular shot due to the lighting, it's not as noticable in person.
Re: '71 Demon Project Build [Re: ScottSmith_Harms] #148767
04/07/09 04:48 AM
04/07/09 04:48 AM
HOUSTON,TX
O
OSO Offline
OSO  Offline
O
HOUSTON,TX
Nice work, its going to great when finished keep up the good work. If i was smart i would build something like that for the motor and trans out of my truck but i am who i am.
Re: '71 Demon Project Build [Re: OSO] #148768
04/07/09 08:20 AM
04/07/09 08:20 AM
ME
79machocharger Offline
ME
It's looking great . To me the duster, dart, demon is one of the hardest car to do as far as body work, they have way too many body lines, and curves. E bodies and b bodies are way easier they have alot less body lines.
Re: '71 Demon Project Build [Re: ScottSmith_Harms] #148769
04/07/09 11:37 AM
04/07/09 11:37 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
Tell e about it. I started to make that mistake with my E58 car...then I realized. Good thing, too!
2 Demons...no, not my kids!
Re: '71 Demon Project Build [Re: ScottSmith_Harms] #148770
04/07/09 11:57 AM
04/07/09 11:57 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Ah, the good ole Duster Dent.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: '71 Demon Project Build [Re: CJK440] #148771
04/07/09 02:09 PM
04/07/09 02:09 PM
san diego
JonsGottaDusta Offline
san diego
DO you know if that was a mold defect or was it meant to be there for some reason? I have always wondered why that was there
Re: '71 Demon Project Build [Re: JonsGottaDusta] #148772
04/07/09 02:34 PM
04/07/09 02:34 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I believe it was supposed to be there as a transition to the door. If you run your hand from the depresion forward it smooths right into the door surface. Not to mention that it's unlikely that the mistake would have been made on both sides of the car. It used to be the last thing I noticed on a car, now it's the first thing I look for, if they aren't there you can be fairly certain that there's mud in the panel to fill it
Re: '71 Demon Project Build [Re: ScottSmith_Harms] #148773
04/07/09 04:50 PM
04/07/09 04:50 PM
4speeds4me Offline
4speeds4me  Offline
I'd say Scott's got it right on. They used the same doors as the Dart's and Valiants, and they were pretty flat sided. That "dent" as it appears, makes them line up better, matching the lines more acceptably.
Re: '71 Demon Project Build [Re: VITC_GTX] #148774
01/01/10 01:18 AM
01/01/10 01:18 AM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Well, eight months and I'm ashamed to say I didn't get a darn thing done on the car until last weekend. I just plain lost interest and got busy doing other things but hopefully now I will get back on it.
Filler is complete (finally) and the car is ready for primer once I DA the the sheetmetal one more time. I've only primed one other car so this is still relatively new and fun for me (hopefully that will keep me motivated).
Couple of pics of the completed filler work.
Re: '71 Demon Project Build [Re: VITC_GTX] #148775
01/01/10 01:21 AM
01/01/10 01:21 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
One more exciting thing happened with the car this week. My AAR six pack hood showed up today.
I bolted it to the hinges and the gaps line up great! It may not even take any work/filler prior to priming (ahhh, probably a little because I'm picky).
Re: '71 Demon Project Build [Re: VITC_GTX] #148776
01/01/10 01:24 AM
01/01/10 01:24 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
One last thing. I want to get this car done as soon as I can so any ribbing , teasing , etc you would like to do to keep me motivated is welcome
Re: '71 Demon Project Build [Re: VITC_GTX] #148777
01/01/10 02:38 PM
01/01/10 02:38 PM
Ok so then why are you sitting at the computer instead of working on the car, are we a little hung over today. Looking great!
Re: '71 Demon Project Build [Re: VITC_GTX] #148778
01/01/10 05:48 PM
01/01/10 05:48 PM
It looks like all the hard work is done!
What's the hold up?
It's always gratifying once you get everything one color and get all of that *#$&^@ bodywork done.
Re: '71 Demon Project Build #148779
01/01/10 07:47 PM
01/01/10 07:47 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Problem usually is you think the body work is done but it isn't until about 200 hours of sanding later.
Sheldon
Re: '71 Demon Project Build [Re: RUNCHARGER] #148780
01/01/10 07:57 PM
01/01/10 07:57 PM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
The car looks great.
I wish I had a garage like that to
work on mine in.
Re: '71 Demon Project Build [Re: VITC_GTX] #148781
01/02/10 01:22 AM
01/02/10 01:22 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks for the encouragment guys, I need it...
I just spent 8 1/2 hours out in the shop working on the car and it doesn't look any different . I spend the day DAing the bare metal and scotch briting all the nooks and crannys under the rockers, rear valence, cowl vents, etc. Also put seam sealer in the truck lip area.
Plans are to go out in the morning and blow it off, mask it and prime it. Is should be ready to go.
Re: '71 Demon Project Build [Re: demon440] #148782
01/02/10 01:24 AM
01/02/10 01:24 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
work on mine in.
Yeah, I'm pretty lucky to have a shop like this. I built it about 5 years ago and I will never be without another.
Re: '71 Demon Project Build [Re: VITC_GTX] #148783
01/02/10 01:52 PM
01/02/10 01:52 PM
Louisville KY.
redmay Offline
redmay  Offline
Louisville KY.
GET OFF your but & get to work if you want your car to look like mine
