Fire Core Distributor Springs #1487697
08/20/13 10:45 PM
08/20/13 10:45 PM
NY
Beep Beep Offline OP
NY
Anyone running a Fire core Distributor? Would like to know which advance springs to use. It came with two blue springs installed. Wanted to know when full timing comes in using these springs.
Re: Fire Core Distributor Springs [Re: Beep Beep] #1487698
08/21/13 03:43 AM
08/21/13 03:43 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
16 to 18 degree's from the factory. Most customers have left it alone, unless racing. Which distributor? Thanks for your business. If you need directions, please let me know. Sometimes they were not put into the boxes.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Fire Core Distributor Springs [Re: sunroofgtx] #1487699
08/21/13 07:12 AM
08/21/13 07:12 AM
NY
NY
Sorry 16 to 18 would be the amount of mechanical advance, I wanted to know at what rpm with the blue springs will it all be in by. Also I did not get any instructions.
Re: Fire Core Distributor Springs [Re: Beep Beep] #1487700
08/21/13 11:34 AM
08/21/13 11:34 AM
Cincinnati, Ohio
superbeedave Offline
Cincinnati, Ohio
This is what I would do. Install the distributor, get your timing tight and tach. Run the car and watch the timing for advancement. At first sign of advance record that rpm down. Then raise your rpm's up until there is no more advance then record that rpm number. Then you will know the rate of advance for those springs. At that time you can decide if you want stiffer springs or loose springs. Or if you want timing coming in earlier or later. I have done this process I bet a hundred times, it can't go wrong. And another thing. You are going to need a dial back timing light or have a balancer with marks up to 50 degrees or more or,, timing tape on your balancer for this to really work. Or not!
Re: Fire Core Distributor Springs [Re: Beep Beep] #1487701
08/21/13 08:57 PM
08/21/13 08:57 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I left the original springs in mine and it's all in by 1800 RPM.Its perfect for a street strip car like mine, it gives you plenty of lead time to get the car moving so you don't get any low end detonation.
Gus
64 Plymouth Savoy
Dana 60
Re: Fire Core Distributor Springs [Re: Beep Beep] #1487702
08/21/13 10:07 PM
08/21/13 10:07 PM
MI
John L Offline
John L  Offline
MI
I left my blue springs in and love the way it runs. No instructions with mine either, very frustrating but figured it out.
Re: Fire Core Distributor Springs [Re: John L] #1487703
08/21/13 10:38 PM
08/21/13 10:38 PM
NY
NY
Thanks Guys!
Superbeedave, sounds good I will give it a try. Currently I am running a MP distributor with the springs that came in the distributor and it is running all in by 2700 rpm. Timing is set to 17 base and 33 total. Running a 500 cube 11:1 all street motor.
At what rpm should the mechanical advance start and be all in at what rpm?
What do you guys recommend?
Rick thanks for the instructions.
Re: Fire Core Distributor Springs [Re: Beep Beep] #1487704
08/21/13 10:52 PM
08/21/13 10:52 PM
Rittman Ohio
Rittman Ohio
We need to know a little more about your entire combo, engine, gear, converter etc...
It all needs to work together.
Gus
64 Plymouth Savoy
Dana 60
Re: Fire Core Distributor Springs [Re: fourgearsavoy] #1487705
08/21/13 11:20 PM
08/21/13 11:20 PM
NY
NY
Okay here I go:
Carter AVS 800
Edelbrock DP4B ported dual plane intake
Ported Stealth heads with Harland Roller 1.5
Solid street roller cam @.50= 236 intake and 243 exhaust, .552 gross valve lift. Lash at .014th intake .016th exhaust
Valves 2.14" intake 1.81" exhaust
Flow rates
intake
.500 - 285
.550 - 289
exhaust
.500 - 217
.550 - 223
400 block with stroker kit to 499 cubes, compression 11:1
3.91 rear gear with 4 speed
Msd box
3900 lbs weight
mechanical edelbrock fuel pump
stock manifolds with 2 1/2 x pipe exhaust
manifold vacuum at idle 14 inches
I hope I did not miss anything. It runs and idles like a clock.
At 1000 rpm timing is 17 degrees at 1500 rpm timing is 25 degrees, never checked when it starts to advance somewhere between 1000-1500 rpm.
Re: Fire Core Distributor Springs [Re: Beep Beep] #1487706
08/22/13 12:22 AM
08/22/13 12:22 AM
Cincinnati, Ohio
Cincinnati, Ohio
So your saying that your base is set at 17 and idles at 1000? This is too tough for me to figure out! If it idles at 1000 I would say start to bring in the mech. adv. at around 1300 or so and all in be 2000-2200 maybe? Is this really an 11.1 compression engine? With 17 degrees adv. and 18-20 mech. I would set full advancement at 35-37 all in by 2000-2200? Guy's, someone chime in and help, This is a little out of my territory!
Re: Fire Core Distributor Springs [Re: superbeedave] #1487707
08/22/13 12:38 AM
08/22/13 12:38 AM
NY
NY
Idles at 800 rpm and base timing is the same at 1000 rpm.
17 base with 16 mechanical, total is 33 degrees @ 2700 rpm
Re: Fire Core Distributor Springs [Re: Beep Beep] #1487708
08/22/13 12:40 AM
08/22/13 12:40 AM
NY
NY
Motor made the most power at 34 degrees total on the engine dyno and wheel dyno.
Re: Fire Core Distributor Springs [Re: Beep Beep] #1487709
08/22/13 03:29 PM
08/22/13 03:29 PM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
Just got my Firecore plug-and-play distributer last week for my 383... no instructions in mine either, and out of the box has 20* mechanical advance.
Paul
'69 Super Bee 383 EFI Turbo
Re: Fire Core Distributor Springs [Re: Beep Beep] #1487710
08/22/13 03:42 PM
08/22/13 03:42 PM
I'd suggest (1) setting the initial with the "vacuum gauge method" then (2) with that figure in hand shorten the slots to get 36 total then (3) plug in vac adv & pick a spring combo that keeps you just under the pinging point at WOT up thru the gears on your hottest/driest day then (4) adj vac adv (2 adjustments). Seperate issue- you want the spring/slot adv to start several hundred RPM above the in gear idle speed (or neutral if stick). Keep vac adv capped off for (1) unless going with manifold vacuum & capped off for (2) whether ported or manifold vacuum. A short stroke 383/400 MAY work well with significantly more than 36 total. You can always change your settings. #1 if you can afford it dont scrimp on the octane.
Re: Fire Core Distributor Springs [Re: RapidRobert] #1487711
08/22/13 10:03 PM
08/22/13 10:03 PM
NY
NY
Thanks everyone for the replies. I am sure it will take sometime to set up. I will give it a try.
Re: Fire Core Distributor Springs [Re: Beep Beep] #1487712
08/26/13 10:00 PM
08/26/13 10:00 PM
NY
NY
I tried running the Fire Core distributor. I set the base timing at 18 and set the mechanical advance at 16 which gave me 34 total. Using 2 blue springs the mechanical advance started at 1100 rpm and the mechanical advance was all in by 2100 rpm. I test drove the car with part throttle runs taking it up to 4000 rpm and I don't hear any detonation. Can detonation be so slight that it would be hard to hear it? Is 2100 to low for a street engine. I double checked my MP unit and it was all in by 2500rpm. Should I change the springs to heavier ones?
Re: Fire Core Distributor Springs [Re: Beep Beep] #1487713
08/26/13 10:53 PM
08/26/13 10:53 PM
I would go WOT when working with the springs. Yes there is silent ping (dont know too much about it tho). I would go lighter till you hear pinging at WOT then go back heavier till it just stops. Right now you have alot of wiggle room as you dont know how close you are to pinging & do check at WOT. You might be close & you might far away & actually be able to use much more advance (faster)
