4150 Carb on 4500 Intake #1487631
08/20/13 07:09 PM
08/20/13 07:09 PM
Colorado
506RR Offline OP
506RR  Offline OP
Colorado
Our class rules require a 4150 carb, but I will be using B1 Original Heads and have the B1 Manifold with a 4500 opening. I also have a 4150 nitrous plate that will be going under the carb.
I would like a 1" open spacer for hood clearance issues. Does anyone make a spacer like this? Or know where I can buy one?
Re: 4150 Carb on 4500 Intake [Re: 506RR] #1487632
08/20/13 07:35 PM
08/20/13 07:35 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
The quick fix would be to swap your base plate with one that is drilled for both patterns. There are adapter plates available, but from memory they are all around 2". A 1" plate isn't going to be feasible due to the two patterns being so close.
Alan Jones
Re: 4150 Carb on 4500 Intake [Re: 506RR] #1487633
08/20/13 07:46 PM
08/20/13 07:46 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
quickfuel and holley both have 4150 carbs with dual pattern baseplates .I think AndyF has an adapter plate as well - may be to suit these style carbs on a dominator manifold
Tex
New best ET 10.259@129.65 .
New best MPH 130.94
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 4150 Carb on 4500 Intake [Re: tex013] #1487634
08/20/13 09:21 PM
08/20/13 09:21 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Holley's latest Ultra series carbs also have a dual pattern. Also, if they are legal, an SV1 has a dual pattern....
Re: 4150 Carb on 4500 Intake [Re: 506RR] #1487635
08/20/13 09:24 PM
08/20/13 09:24 PM
AndyF Offline
AndyF  Offline
Yes, I make a 1/2 inch shear plate adapter that works in that situation. You need a base plate with the dual bolt pattern. I've done some dyno testing with this shear plate and it works pretty well. For your application you probably want something large like the new Holley 950.
Re: 4150 Carb on 4500 Intake [Re: AndyF] #1487636
08/20/13 10:01 PM
08/20/13 10:01 PM
Colorado
506RR Offline OP
506RR  Offline OP
Colorado
I currently have a 4150 1000cfm Holley that does not have the dual pattern base plate. Also, the 4150 nitrous plate is another reason for needing the 4150 bolt pattern.
If i buy a different base plate, I also have to buy a 4500 nitrous plate.
Re: 4150 Carb on 4500 Intake [Re: 506RR] #1487637
08/20/13 10:15 PM
08/20/13 10:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I think you have enough material on your manifold to
take some alum rod and thread it and install in the
4500 holes then re-drill it to 4150... you can glue
the rod in or weld it in... set your 4150 on it to see
Re: 4150 Carb on 4500 Intake [Re: MR_P_BODY] #1487638
08/20/13 10:30 PM
08/20/13 10:30 PM
LA360 Offline
LA360  Offline
Alan Jones
