Re: 4150 Carb on 4500 Intake
[Re: 506RR]
#1487632
08/20/13 08:35 PM
08/20/13 08:35 PM
Posts: 6,142 Melbourne , Australia
LA360
The quick fix would be to swap your base plate with one that is drilled for both patterns. There are adapter plates available, but from memory they are all around 2". A 1" plate isn't going to be feasible due to the two patterns being so close.
Alan Jones
[Re: 506RR]
#1487633
08/20/13 08:46 PM
08/20/13 08:46 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
quickfuel and holley both have 4150 carbs with dual pattern baseplates .I think AndyF has an adapter plate as well - may be to suit these style carbs on a dominator manifold
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: 506RR]
#1487637
08/20/13 11:15 PM
08/20/13 11:15 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Our class rules require a 4150 carb, but I will be using B1 Original Heads and have the B1 Manifold with a 4500 opening. I also have a 4150 nitrous plate that will be going under the carb.
I would like a 1" open spacer for hood clearance issues. Does anyone make a spacer like this? Or know where I can buy one?
I think you have enough material on your manifold to take some alum rod and thread it and install in the 4500 holes then re-drill it to 4150... you can glue the rod in or weld it in... set your 4150 on it to see
