1963 Poly 318 - will later model 727 bolt-up to it? #1487572
08/20/13 07:09 PM
08/20/13 07:09 PM
VA
AtomicDog Offline OP
VA
I have a friend that is using a 1963 poly 318. Does anyone know if any small block 727 transmission from the mid 1970's will bolt-up to it and operate?
Re: 1963 Poly 318 - will later model 727 bolt-up to it? [Re: AtomicDog] #1487573
08/20/13 08:03 PM
08/20/13 08:03 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The trans will bolt up but convertors are different.I think you can use the late convertor on the poly but not the poly on the later crank.The difference is the register diamiater on the crank.We put a LA in the 66 Charger after the poly locked up.One bolt wont line up IIRC but it works.You can not swap convertors from late to new either.I believe 66 was the last year for different splines on the convertor.Rocky
Chrysler Firepower
Re: 1963 Poly 318 - will later model 727 bolt-up to it? [Re: therocks] #1487574
08/20/13 08:36 PM
08/20/13 08:36 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
early converter snout is smaller than the later, so you can't swap late to early, but you can have a converter made to fit the later trans and the early crank. Years ago I got a quote from a local trans shop that was reasonable and they knew what I was talking about, so call around.
Don't be the exception.
Re: 1963 Poly 318 - will later model 727 bolt-up to it? [Re: Supercuda] #1487575
08/20/13 10:39 PM
08/20/13 10:39 PM
Andrewh Offline
Andrewh  Offline
there must be something that can be done on the crank as well.
the old trick to get a forged crank was to steal one out of a poly and rebalance for a 340.
Re: 1963 Poly 318 - will later model 727 bolt-up to it? [Re: Andrewh] #1487576
08/21/13 03:48 AM
08/21/13 03:48 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Most any converter company will make a small pilot converter.
Edge or Continental used to do them for less than $200.
Re: 1963 Poly 318 - will later model 727 bolt-up to it? [Re: Andrewh] #1487577
08/21/13 03:54 AM
08/21/13 03:54 AM
dogdays Offline
dogdays  Offline
I am putting a 86 318 in my '64Dog. I know for a fact that the bolt below the driver side dowel is in a different location vertically. You should be able to drill from the newer trans into the Poly flange and install a 3/8 or 7/16 bolt.
As far as the torque converter nose I'll have to check if there's enough material to bore it out.
Keep in mind that 340s were usually mated to 4-speeds back in the day, at least among those who may have swapped in a forged 318 crank.
R.
Re: 1963 Poly 318 - will later model 727 bolt-up to it? [Re: dogdays] #1487578
08/21/13 05:54 AM
08/21/13 05:54 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
When you mate a post '67 motor to a pre '68 trans you can get a spacer ring for the crank register that will let it accept the small converter pilot.
Re: 1963 Poly 318 - will later model 727 bolt-up to it? [Re: slantzilla] #1487579
08/21/13 07:25 AM
08/21/13 07:25 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
He's doing the opposite.
Re: 1963 Poly 318 - will later model 727 bolt-up to it? [Re: Supercuda] #1487580
08/21/13 11:11 AM
08/21/13 11:11 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Look at the post above mine.
Re: 1963 Poly 318 - will later model 727 bolt-up to it? [Re: slantzilla] #1487581
08/21/13 01:41 PM
08/21/13 01:41 PM
dogdays Offline
dogdays  Offline
I am using the original NP420 so I personally care nothing for the torque converter ring problem. I said I'd check it out for the OP, who is using an automatic transmission.
R.
Re: 1963 Poly 318 - will later model 727 bolt-up to it? [Re: therocks] #1487582
08/21/13 02:17 PM
08/21/13 02:17 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The converter hub diameter difference only relates to the 904, all 727 converter hubs are the same diameter.
All '62-later poly cranks had the large register, only the early /6 and 273 had the small register.
The only problem encountered when mating a later 727 to a poly is the bellhousing bolt pattern, there is one bolt hole that won't align.
Re: 1963 Poly 318 - will later model 727 bolt-up to it? [Re: John_Kunkel] #1487583
08/21/13 03:14 PM
08/21/13 03:14 PM
dogdays Offline
dogdays  Offline
Thanks, you answered my question, though I didn't ask it!
So the late pilot bearing will work in my Poly crank, if I ever decide to rebuild it.
Also, the hole that doesn't line up is drivers side below the dowel, with enough material to be able to drill and tap a hole that will work.
R.
